Moonroof Rattle Solution
sup fellas,
i just recently found out that the rattling moonroof issue can be minimized without any fixes or mods. but let me ask first, do you guys get the rattling when your moonroof is open all the way? if yes, then try this.
this is what i found out. when you open ur moonroof all the way, it actually DOES NOT OPEN ALL THE WAY. when the moonroof slides open and stops, give the *** another pull to open it and you will see the moonroof open another inch or 2. you will notice an improvement and you won't hear the rattles unless you hit some really big bumps or potholes. hope this helps.
