Engine will not start, In need of help
Old Dec 19, 2011 | 04:11 PM
bjlisiono's Avatar
bjlisiono
Default Engine will not start, In need of help
Hey guys
On my 99 GS400, there was a random misfire in cylinder 6 and just this morning my brother and I changed the spark plugs to brand new NGK Iridium IX spark plugs. We took the car out for a drive to see if it was working and then we heard a sound coming from the engine, we pulled over and the car died.
My brother just tried to remove the spark plug in cylinder 6 and it was seized in there. A large chunk of the spark plug is missing: (sorry for the very large pics)
Did this ever happen to anyone?
Old Dec 19, 2011 | 05:00 PM
cschroder's Avatar
cschroder
dude your motor is toast
Old Dec 19, 2011 | 05:18 PM
abounly's Avatar
abounly
holy that sucks. i dont know how yo'll be able to pull it
Old Dec 19, 2011 | 05:36 PM
NEbiker10's Avatar
NEbiker10
Looks like you over tightened them a lot
Old Dec 19, 2011 | 05:47 PM
bjlisiono's Avatar
bjlisiono
Spark plugs were not torqued, only hand tightened with a rachet.
Old Dec 19, 2011 | 06:11 PM
ThomasGS4's Avatar
ThomasGS4
Can't say I've ever seen that before. Best of luck to you.
Old Dec 19, 2011 | 06:56 PM
NEbiker10's Avatar
NEbiker10
Can there be such a thing as a faulty plug exploding?? Lawsuit for new engine??
Old Dec 19, 2011 | 07:47 PM
bjlisiono's Avatar
bjlisiono
Thanks. I'll be taking the car to my mechanic on Wednesday.
I am going to call NGK's customer service tomorrow morning and file a claim. I've been using NGK Iridium spark plugs for years and this is the first time that it blew up.
Old Dec 19, 2011 | 09:18 PM
ThomasGS4's Avatar
ThomasGS4
Coil pack issue?
Old Dec 19, 2011 | 10:23 PM
blisiono's Avatar
blisiono
I don't think so. I swapped the coil pack from the misfiring cylinder to another cylinder and the spark plug in that one looked fine. I also tried to install the old spark plug in the same cylinder but at a point, the electrodes on the spark plug got bent inwards meaning that the piston is possibly higher up than what it should be.
Old Dec 19, 2011 | 11:23 PM
clos430's Avatar
clos430
Could it be you guys installed a wrong spark plug in that cylinder ? Wow never seen that before
Old Dec 20, 2011 | 06:47 AM
shvc1991's Avatar
shvc1991
Ouch. Time to upgrade... 430. =]
Old Dec 20, 2011 | 07:09 AM
blisiono's Avatar
blisiono
Nope, checked the spark plugs to make sure they were the same type and correct for the car.
or an LS1
Old Dec 20, 2011 | 01:49 PM
NEbiker10's Avatar
NEbiker10
Almost looks like something to do with timing and maybe a cylinder head might of hit it
Old Dec 20, 2011 | 02:05 PM
AKS14's Avatar
AKS14
Looks like the motor dropped a valve or sucked something through the intake.. I know its a pretty common issue in some nissan motors that have intermediary 'butterfly valves' in the intake manifold to have the bolts come loose and suck through the motor causing similar damage although usually not quite as extreme..
At any rate that motor is most likely toast.
