Bad Ground?
Old Dec 8, 2011 | 03:57 PM
shvc1991's Avatar
shvc1991
Default Bad Ground?
So I went ahead and installed my DEPO LED tail lights the other night. I thought everything went fine, but I noticed today while backing up towards a truck, I saw in the reflection that the left trunk light would go out as soon as I hit the brakes and then come back on as soon as I let off. I also noticed that this only happens when the headlights or parking lights are on.
I think it may be a bad ground and if it is, I'm unsure of how to fix it.
Can anybody provide some insight on how to go about fixing this or if it may be another problem?
I'd appreciate any help.
Old Dec 8, 2011 | 04:43 PM
Mr Jokster's Avatar
Mr Jokster
Flip the plugs around. Your brake plug is swapped with the running. Since they both have the same plugs (the plugs that are on the lights themselves) you cant tell which is for which, I think most have had that issue
Old Dec 8, 2011 | 05:02 PM
shvc1991's Avatar
shvc1991
That's for the outer lights. Those have no issue. It's the trunk lights that are giving me a problem.
Old Dec 8, 2011 | 07:30 PM
bennylex's Avatar
bennylex
i had the same exact problem when i installed mine a week ago. The plug going into the light itself has two little metal wire connections that may be a bit off. Just readjust them and plug the connection going into the light and see if it works!
Old Dec 8, 2011 | 09:35 PM
shvc1991's Avatar
shvc1991
^ Just fixed it! It was exactly what you said. Thanks!
Old Dec 9, 2011 | 05:25 AM
bennylex's Avatar
bennylex
no problem, glad i could help!
Old Dec 9, 2011 | 06:17 AM
shvc1991's Avatar
shvc1991
It was very much appreciated sir. I hope it doesn't keep doing it.
Old Dec 9, 2011 | 02:35 PM
bennylex's Avatar
bennylex
same here, im paranoid about that stuff haha. in the past week ive checked at least 5 times before driving that they still all work when i hit the brake, so far everythings been good!
Old Dec 10, 2011 | 06:35 AM
shvc1991's Avatar
shvc1991
You're not the only one. Haha.
Toyboy300
Mar 1, 2017 02:58 PM
Jsolo89
Mar 19, 2016 09:29 AM
Zjavelin
Oct 30, 2006 07:00 PM
6thGenMax
13
Sep 3, 2006 01:09 AM
TGRich
Lighting
Dec 13, 2003 01:03 PM
