stock tire keeps deflating
Old Sep 21, 2002 | 11:54 PM
meZoom!'s Avatar
meZoom!
Super Moderator
Default stock tire keeps deflating
this is really starting to get annoying. about a month ago my dad was driving in his 2000 platinum GS300. he said he heard a really loud BANG, going about 40 mph. he got out, checked all tires, as he was sure he had a blowout....but nothing. he says it sounded almost like those empty 1 gallon sparkletts bottles being popped or stepped on, but he is quite sure he didnt step on anything. now, the right rear (#4) tire has trouble maintaining air pressure, but visibly, there is no puncture/nail/etc. at fist he drove cautiously, but now he's like forget it, and went back to driving normally. i guess i could have the tire checked at next oil change, dismounted and separated from the wheel. it is the stock platinum series wheel with the DUNLOPs. anyone have any ideas?
Old Sep 21, 2002 | 11:58 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Take it to a tire place and have them check it (I've usually had them do it for free). They can pull the entire wheel/tire, visually inspect it or submerge it to locate leaks.
Those weird punctures seem to happen where you don't see 'em.
Good luck!
Old Sep 23, 2002 | 11:49 AM
Nimbus's Avatar
Nimbus
If he has no punctures in his tire, check the valve stem, it could simply be loose.
Old Sep 23, 2002 | 03:12 PM
Richie's Avatar
Richie
Maybe a long shot, but it could be some oxidation on the wheel.
Old Sep 23, 2002 | 03:53 PM
GS430 GUY's Avatar
GS430 GUY
CL Folding 200,000
Could be a bent rim as well. Have a tire place check the wheel out and you'll get the proper diagnosis. All we can do on here is speculate for you
Old Sep 23, 2002 | 07:04 PM
mooretorque's Avatar
mooretorque
Talking
Bottom line is, somebody (and it can be you) needs to take the wheel and tire off and swab the beads, the valve stem and the tread with a mixture of soapy water. The bubbles will tell you where the leak is but you will be going to a tire place to get it fixed, regardless, so why not save yourself the trouble and let them do it all?
Old Sep 25, 2002 | 03:56 AM
meZoom!'s Avatar
meZoom!
Super Moderator
thanks for the help guys. for the time being, i dont have the time or energy to dismount the tire and find a bucket big enough to fit the tire in to submerge it...so i gunked a can of fix a flat spray in there....i know i dont have a puncture FOR SURE but i did it anyway. i guess i will have my dad take it to the shop on HIS own time and with HIS money $$$$
Old Sep 25, 2002 | 09:06 PM
pvmike1's Avatar
pvmike1
If you are near Torrance, go to American Tire on Hawthorne. They fix tire leaks for free (if that's what the problem is).
RollingBlu
RX - 4th Gen (2016-2022)
Apr 20, 2018 08:25 AM
djkneekap
May 3, 2011 07:30 PM
I8ABMR
Feb 4, 2009 10:18 PM
acl15
Apr 21, 2006 03:38 PM
martini3
Wheels, Tires & Brakes Forum
Dec 16, 2004 05:21 AM
