12 inches +
Old Jun 24, 2011 | 07:24 PM
sam430's Avatar
sam430
Default 12 inches +
okay, who is rolling on 12" or wider wheels? can you provide specs and pic of stance?
I have the 37LE 10.5"/19 +21
I wanna stretch it another 2" towards the inside, basically 12.5"/19 +21
vroom vrooooom!
Old Jun 24, 2011 | 07:56 PM
VNN326's Avatar
VNN326
19x11 19x12 +22 AC Supreme
Old Jun 24, 2011 | 08:28 PM
5t341th's Avatar
5t341th
your offset will change if u widen the inside barrel. its not going to stay the same. unless u widen the lip, which makes the offset more negative
Old Jun 24, 2011 | 08:48 PM
Sonic_RC's Avatar
Sonic_RC
^^ Yup, making the inner barrel with make your offset higher and widening the outer lip makes it more negative. Adding the same amount to both sides will keep the offset the same.
12.5 +21 would mean 1" wider inside and 1" wider on the outside compared to your current setup. If you want it to be bigger by 2" only on the inside that would make it 12.5 +46. I don't think that would clear the struts. I think you can get away with 12" +40 with your current setup. making it 1.5" wider on the inside and the outside would sit the same
PS: BiggVinh your car is on point!!!!
Old Jun 24, 2011 | 09:22 PM
airmax's Avatar
airmax
any full shots BiggVinh?
Old Jun 25, 2011 | 02:39 AM
sam430's Avatar
sam430
YES, thanks for clearing that up guys... i was mathematically challenged when I had the brilliant idea LOL...anyhow, I'm gonna measure to make sure I can fit that extra .5" ...but 12" is good enough I guess.
Old Jun 27, 2011 | 11:34 PM
sam430's Avatar
sam430
Anyone else?
Old Jun 28, 2011 | 12:55 AM
dejavu157's Avatar
dejavu157
big vinh really? u wanna recommend them that size?
RavSpec
Feb 28, 2014 07:27 AM
blazeone44
Mar 24, 2009 04:31 AM
D2-AUTOSPORT
Club Lexus Vendor Marketplace
Dec 4, 2005 07:26 AM
TNH
Wheels, Tires & Brakes Forum
Oct 11, 2004 01:22 AM
HKS JZS161
Jan 3, 2002 07:15 PM
