Probably not a record BUT!
Old Feb 10, 2011 | 04:59 PM
entryspeed's Avatar
entryspeed
Default Probably not a record BUT!
Well, as some of you may know I just bought a my first gs400, I paid little for it In my opinion but now I have to assume the car was well taken care of in the fluid department because. The car has 200k on the ticker and the owner I bought it from didnt know when the last time the Timing belt was replaced or any major maintenance for that matter but he had a 30k miles of oil change and fluid flush logs. So as soon as I got it home I noticed the cam seals leaking and immediatly went to have them replaced as well as the whole timing kit ie (belt, tensioner, idlers, water pump gaskets etc) and valve cover gaskets. When me and my uncle broke it down we found the original timing belt from day one as well as tensioner idlers and water pump. I thought dam let me look at this belt to my surprise no teeth missing but had some hellacious cracks in back strap. The water pump however showed no signs of wear on the impeller at all and was very clean but was date coded 99 it looks like. So this car must of really had a life of pampering or its a good testiment to how well things are really made from toyota. The tensioner however was still working but was rusty as all hell.
Old Feb 10, 2011 | 06:12 PM
cmara2k9's Avatar
cmara2k9
Our cars are built too last!
Old Feb 10, 2011 | 06:49 PM
breadbeat's Avatar
breadbeat
Thats good news! Im just about to hit 195k. Which means I can put off this timing belt thing just a little while longer.
Old Feb 10, 2011 | 06:54 PM
j stuff's Avatar
j stuff
breadbeat.. you never got Tbelt done? just be cause someone went that far without it doesnt mean you will have such luck.
You should do it asap
Old Feb 10, 2011 | 07:13 PM
breadbeat's Avatar
breadbeat
Previous owner had it done around 90k or whenever the manual recommends but it hasnt been done again as far as the service history tells. But dont worry its on my list... I just really need to get these coil-overs first.
Old Feb 10, 2011 | 07:49 PM
TLcoats's Avatar
TLcoats
Toyota built their stuff to last! Look up that Top Gear where they tried to kill an old Toyota pickup. They crashed it, dumped it in the ocean, lit it on fire and it still ran.
KlausO
Dec 3, 2017 02:29 AM
toytrain13
Sep 25, 2012 08:35 AM
iman61701
Oct 26, 2010 03:42 PM
Slvr surfr
Sep 20, 2010 11:00 PM
trackball
Aug 12, 2010 12:10 PM
