blown headgasket easy fix?
Old Jan 18, 2011 | 10:21 PM
Globalinx's Avatar
Globalinx
Is it 200K miles? or Kms? I saw a normal and drivable 99 with 220k miles for $1800 at the auction.
Old Jan 18, 2011 | 10:38 PM
sam430's Avatar
sam430
Originally Posted by GSteg
You have to have a pretty big gasket failure to get anything out of a compression test. If your headgasket is only seeping, your compression difference may be too small come to a solid conclusion
A hydrocarbon test (aka block test) isn't overboard at all, and certainly not as extensive as a compression test. You fill up a tube with a solution they give you. Remove your radiator cap and place the tube over the radiator's spout and turn on your engine. If combustion gas is present in the cooling system, the color of the solution will change. Most of the solutions they have in the market is blue and will change to green or yellow (when its really bad). The color will change even at the slightest hint of hydrocarbon.
I did that to my car... it's very light colored and very hard to see if there is any change. Did I get a watered down version?
Old Jan 19, 2011 | 04:36 AM
YviE's Avatar
YviE
I recently had a blown HG on my Toyota Previa. The hydrocarbon test came back negative and the compression test gave good results. The car did burn coolant though, that was the only indication of the HG failure.
Old Jan 19, 2011 | 06:04 AM
GSteg's Avatar
GSteg
If the color changed just a bit, then it just means you have very very little hydrocarbon. It's not a major failure so keep your coolant level full and you should be good for a while.
Old Jan 19, 2011 | 06:08 AM
GSteg's Avatar
GSteg
Does white smoke come out of the tailpipe? Sometimes the color change is subtle, and you must run the car for a while to let the air make it back up to the radiator neck.
How much coolant were you losing? Did you do a leakdown test to make sure it wasn't leaking. My father's 93 Camry V6 had the same issue. I had to pour in coolant every 3 weeks because it would be low. I thought it was a headgasket issue but it turned out to be a leaking hose. The rate of the lost was so low (maybe 6 drops per day?) that the any coolant that leaked would be burned up by the engine right away so I never found it without a leakdown test.
Old Jan 19, 2011 | 07:01 AM
aka paco's Avatar
aka paco
Originally Posted by trickz
i would get it if i was you. you can get a the whole block for a few hundred bucks because nothing wrong with the trans.. or even better just go for the turbo swap
Ditto
Old Jan 19, 2011 | 07:02 AM
YviE's Avatar
YviE
@ GSTeg
Yeah the car was blowing white smoke. That's why I began thinking I had a blown HG. Took the car to the mech' and he did the test I previously mentioned. He was pretty sure it wasn't a blown HG.
I was also losing coolant. So my mech' looked at it again and found a leaking hose, which he replaced. But then the car began smoking more and more and when the engine was warm it would stall for some reason (had to wait for it to cool before it would start again).
That's when we decided to open the engine and saw that it was indeed a blown HG.
Old Jan 19, 2011 | 07:59 AM
flexspeed's Avatar
flexspeed
i take the car.... offer him less... after that... i just do a gte swap ,,..
Old Jan 19, 2011 | 09:12 AM
slvrboolet's Avatar
slvrboolet
ya waiting to hear back if he still has it after retard didnt answer phoen and someone else got to look at it first.
Old Jan 29, 2011 | 08:44 PM
oscar430's Avatar
oscar430
Buy a leakdown tester @ Harbor Frieght for $35.00 you need some compressed air & the guages screw right into the spark plug hole on a hose. Air it up on TDC compression & the guages will tell you if you have a leak. Look up a leakdown tester on google I have one & they work great! Also look for oil in the water or water in the oil.
Old Jan 30, 2011 | 11:58 AM
GS4_Fiend's Avatar
GS4_Fiend
Or just bring it to a smog station and let them do the sniffer test.
Old Jan 30, 2011 | 05:05 PM
92sc300nj's Avatar
92sc300nj
well its probally blown to to overheating.. id do a thermostat from lexus while your at it but its not entirely difficult you might be able to get away with doing it over a couple days while mil-ing the head.. just make sure you have accurate torque wrench..
Old Jan 30, 2011 | 05:07 PM
92sc300nj's Avatar
92sc300nj
well if it doesnt work out like you dont feel like doing it .. keep me in mind.. ill do it lol
Old Jan 30, 2011 | 07:48 PM
CK6Speed's Avatar
CK6Speed
Me personally, I wouldn't buy it due to the fact it is a confirmed blown head gasket, overheated engine with 200K miles on it. Unless you are factoring in the cost of the car, plus an engine swap there are better deals out there. Heck, too bad you are not in Hawaii. I'm selling my 03 GS430 with 149,xxx miles on it without a blown HG for $5K. Or at least I will be soon.
Old Jan 30, 2011 | 07:51 PM
ThomasGS4's Avatar
ThomasGS4
$5k? Why so cheap?
Joeb427
Jul 24, 2010 06:32 PM
masboy
Great Deals
Feb 26, 2009 12:28 AM
Carfreak70
Oct 5, 2008 09:04 PM
5gears-IS
Great Deals
May 17, 2008 11:28 PM
boostedny
NELOC
14
Aug 5, 2007 01:27 PM
