trailing arm bushing???
Old Dec 18, 2010 | 09:46 AM
tither777's Avatar
tither777
Default trailing arm bushing???
trailing arm/caster bushing??? anywhere except daizen???? thanks
Old Dec 18, 2010 | 01:20 PM
TLcoats's Avatar
TLcoats
Are you really expecting someone to respond to this. Search!
Old Dec 18, 2010 | 08:00 PM
tither777's Avatar
tither777
ive been searching for two days and only seem to find the lower bushings, or upper or for older models…. i thought someone might have some insight with the back order of the dazien castor bushings….
by the way, Yes is the answer to your question… i am hoping for some help, i have done my do diligence with no success, so im asking for help….. people help each other is what i see on this forum the most , people helping people… its a nice way to live!
Old Dec 18, 2010 | 08:01 PM
tither777's Avatar
tither777
2000 GS 300 is what im looking for…. thanks for your help!!!!
Old Dec 18, 2010 | 08:46 PM
98GS400GUY's Avatar
98GS400GUY
http://www.partsgeek.com/catalog/200...m_bushing.html
Old Dec 18, 2010 | 10:26 PM
98GS400GUY's Avatar
98GS400GUY
Just kidding. http://www.l-tunedparts.com/product/?id=3297
Old Dec 19, 2010 | 08:37 PM
tither777's Avatar
tither777
ahhhhhhh……. thank you!!!!!!! THANK YOU!!!! that is just what i was looking for… the other post you had was the kind i kept finding…. Much APPRECIATION!!!
Old Dec 20, 2010 | 08:20 AM
sakataj's Avatar
sakataj
Originally Posted by 95GS300GUY
thats a AWFUL price BTW for ONE bushing...
$50 for one bushing or waiting on the daizen kit with ALL the bushings for like $115
Old Dec 20, 2010 | 09:03 PM
tither777's Avatar
tither777
its high… but in stock!!!!!! the shake is whats awful
Old Dec 21, 2010 | 11:25 AM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
Which bushings are these replacing? The Daizen control arm kit consists of 8 bushings, so changing only 2 of the bushings is no guarantee that the "shakes" will go away 100%. Six of them look like the same size bushing, so if you can order six, plus the larger pair that would be great.
Yup: 2 bushings for $100 vs. 8 bushings for $115
And as I mentioned above, the non-Daizen parts available are not a complete kit. I can just imagine noobs getting replacing only 2 of the 8 bushings thinking they have what they need, then we'll see posts about "I've changed bushings but still got the shakes, what else?" then people will say, change ball joints, road force-balance rims, yada, yada, spend more time and money fixing things that may not be causing the problem and then at some point it will be like "Oh, you only changed 2 bushings?, you should of replaced all the bushings" = FAIL.
Old Dec 21, 2010 | 08:13 PM
diamondmit's Avatar
diamondmit
Default Also look for ADUS bushings....there is a good website
check out www.mybushings.com also http://www.toyheadauto.com/Performan...1990_to_111994
the second one is best
good luck!
dd
Old Dec 21, 2010 | 08:26 PM
sakataj's Avatar
sakataj
hahaha yeah that would be a def fail
Old Dec 21, 2010 | 09:12 PM
tither777's Avatar
tither777
wow... some just post to post! thanks for the help for the ones that were helping. i found the LAST two that i needed to go with the arms, ball joints, tie rod ends, steering and sway. along with brakes and rotors while its apart. thanks again and Merry Christmas!!
bentleymp2
Suspension and Brakes
Jan 8, 2016 09:28 AM
daddyduke
Aug 4, 2015 02:53 PM
kondratus
Jan 10, 2012 03:41 PM
vipjason
Mar 1, 2011 12:49 AM
tonysgs300
Dec 30, 2009 09:10 AM
