maintenance question
Old Dec 17, 2010 | 07:46 AM
simplicity's Avatar
simplicity
Default maintenance question
hello everyone im a owner of 2001 gs300 and i just hit 120 thousand miles and wants to do a maintenance on the car. anyone can give me a list of things i need to get done on the car? like timing belt, water pump,spark plugs, flush out all oils... thanks guys!
Old Dec 17, 2010 | 07:53 AM
LuxuryGS3's Avatar
LuxuryGS3
You should've done the Timing Belt and Water Pump @ 90K miles, so if you didn't do it then, you should do it asap along with spark plugs, transmission fluid, differential, brake, oil, and probably want to change your gaskets.. Those usually end up leaking, so while you're in there doing your spark plugs i'd do the gaskets. I'd also seafoam the car before you change the plugs.
Old Dec 17, 2010 | 08:01 AM
simplicity's Avatar
simplicity
i got the car at around 113 thousand miles and i had my friend from lexus check when it was the last time the car went for a service, it says it was on its 60 thousand miles... sorry which gasket it is?
Mike234588
May 8, 2017 07:50 PM
DaveJ
Oct 29, 2009 02:33 PM
vwynn
Maintenance
Aug 17, 2009 07:10 PM
Och
GS - 1st Gen (1993-1997)
Feb 14, 2003 01:57 AM
