Oil leak question
I have a 98 gs 400 with 187k on it. I replaced the spark plugs a while back. a few of them had oil on them and around the boot. Not inside combustion area. I'm thinking its a leaking valve cover gasket. Same way on both sides. Is this a very hard fix. Also are there any diy threads on this and what would be expected cost to have this done.
It's probably the valve cover gasket that's leaking. The gaskets aren't expensive and shouldn't be hard to replace. I have a 300, so I'm not familiar with the 400. But no need to panic.
lbs, and the spark plug bolts to 35in-lbs when I asked Lexus dealer mechanic. Good luck. Let me know if you need help.
Thx. Just looks like some stuff would have to be taken off just to get valve covers off. I may be wrong. Didn't look real hard. Also im confused on this boot tool. My plug wires came off very easy from the spark plug. Will I have to take plugs out also before I can get valve covers off
Sorry for the terminology confusion, it sometime call the boot but the correct term is spark plug tube seal. No, it is not that difficult to do. I like said if you can do brake, you can do this. Just be careful not the damage the lips around where the seal sits when you pry it off with the very flat tip screw driver, or using the tool I mention earlier. If you don't feel up to the task, you can leave it for the mechanic, but I feel you can tackle this yourself. Take you time during the process and don't over torque the bolts. After you replace those tube seals, it is a good time to remove the spark plugs with oil contamination and clean the plug and the tube good. Good luck.
931UZFE
Jun 20, 2017 06:33 AM
Doublebase
Aug 24, 2015 11:34 AM
Measured
Jun 5, 2015 02:30 PM
xdubber
Jan 14, 2010 02:53 PM
