master key programming,need help
Old Nov 7, 2012 | 01:55 AM
credle89's Avatar
credle89
i try this but it only program my second master key to unlock and lock and trunk open but not start the car like my first master key
Old Sep 3, 2013 | 01:42 PM
shurian's Avatar
shurian
Try this instructions
http://www.remotesremotes.com/1999-L...ker-s/4407.htm
Old Sep 9, 2013 | 04:18 AM
credle89's Avatar
credle89
Originally Posted by shurian
Thanks I will try this and get back to you
Old Apr 22, 2014 | 10:55 AM
inffc's Avatar
inffc
Hi Please Help!!
I tried both way several times but still can't program the key. I just can't make the car into programming mode. One of my rear door actuator is broken, will that be the reason that I can't program?
Thanks
Old Mar 21, 2015 | 08:06 PM
cali99300's Avatar
cali99300
Originally Posted by AMSMIKE
Great info. Thanks. This is certainly different than what I have seen posted in other threads.
One question. If I need to program 2 master keys, do I do the whole procedure for each key?
Mike, Thank you. Your instructions worked. It took two tries because I did the lock/unlock a bit too fast I believe. I would add one thing to step 3. I held both my original key and one new key at chest level simultaneously. I did the whole process again to program the second remote.
For key programming check out this thread:
https://www.clublexus.com/forums/gs-...999-gs300.html
Last edited by cali99300; Mar 21, 2015 at 09:50 PM. Reason: found solution to key programming problem on another thread
Roley954
IS - 1st Gen (2001-2005)
Oct 9, 2012 04:28 PM
Ariyanna
40
Mar 7, 2011 07:35 AM
MulRuBul
RX - 1st Gen (1999-2003)
Feb 27, 2011 04:00 PM
lexkwizit
Aug 13, 2009 03:31 PM
