I am trying to reset my new garage door and set-up to the new one, but can't figure it out. I looked in the DIY and I could't find topic which related to the setting garage door. I also look into the manual and it is not a lot of instruction to go by. Could anyone here point to the right direction, pls? I need an instruction on how to set-up the garage door. Need help, pls. Thanks in advance. I have GS400'98.
you looked in the DIY but didnt search for it after that.....?
I can't set mine up -_-
I even went to Lexus & they failed to get it to work
They said I need to do it from the "Brain" I did & still nothing so I gave up
Yes, the instructions are in the manual. I just had to reprogram mine.
You will need access to your garage remote. If your opener has a rolling code feature (and almost any newer one will), you will need to program the Homelink to the opener.
Step 1. Homelink to Remote programming.
Step 2. (If needed) Homelink to Opener programming.
If you don't perform step 2, nothing will work. This is why Lexus cannot do it at the shop.
do everything the manual tells u then push the learn button on ur opener "not ur remote the actual opener" it should be a red or blue button!!!this should be ur last step which is usually unclear to most people....
Reason: spelling
