Hows my allignment after being lowered?
Old May 7, 2010 | 11:16 PM
SlowGS4's Avatar
SlowGS4
Default Hows my allignment after being lowered?
Just got an allignment last week after lowering my car on nf210 w/ kyb and front RCA. I need help reading my allignment sheet.. and if they did a good job. The front is lower than I'd thought it would be and now the car looks uneven.. df210 in near future.. also which setup would wear my tires quicker? my current setup or the df210?
No fender gap up fronts and 1 finger in the rear..
Some camera phone pictures will be posted soon.. hoping to do a small photoshoot next weekend..
Old May 8, 2010 | 09:22 AM
GSteg's Avatar
GSteg
How come you're using RCAs? Do you have LS400 calipers?
The front RCAs are making your camber worse than it's suppose to be. Your camber should be around 1.5 degrees without the RCAs.
Everything else looks fine except maybe for the caster. If you're on original arms, then its probably worn out if you haven't been in any accidents.
Old May 8, 2010 | 10:09 AM
GS4_Fiend's Avatar
GS4_Fiend
Interesting. Is it because u got RCA that's why u are that low? I got the same setup with 18 inch wheels and I got 3 finger gap in front and 2 finger gap in rear. What size rim u got? Do u have a gs3?
Old May 8, 2010 | 10:26 AM
SlowGS4's Avatar
SlowGS4
I wanted another inch drop without having to replace the springs.. (lazy route).. then it droped the car more than i expected...
Old May 8, 2010 | 10:32 AM
SlowGS4's Avatar
SlowGS4
im on 20x 8.5/9.5. my tires are almost tucked in front. I have a gs400.
heres a picture of how it looks.. theres someone in the car in the second picture.
Attached Thumbnails Hows my allignment after being lowered?-011.jpg   Hows my allignment after being lowered?-012.jpg
Old May 8, 2010 | 11:25 AM
GSteg's Avatar
GSteg
Whichever setup you run (NF or DF), run them without RCAs. Those springs by default lower the the front more than the rear so you should be able to get pretty much an even gap all around. I had RCAs for my previous setup (L-tuned springs) because the springs lowered the car 1" all around. With the stock front gap being larger than the rear, you could see why I RCAs were beneficial.
Old May 8, 2010 | 02:33 PM
CK6Speed's Avatar
CK6Speed
Which brand front RCA are you using? Exact or Sage or other? I run Sage rear (1.1") and Exact front (1.5") and I still could go about 1/2"more in the front for an all around even drop. Anyway, with just drop springs alone you would be at the end of the stock components adjustability. Adding the RCA's surely pushes it beyond its adjustment range. With my RCA's only on stock springs I'm within spec, but not much more adjustment room left on the stock arms.
If you are on Exact fronts getting Sage fronts will raise the front up about 3/8". Still your alignment will be out of spec. If you are going to run both drop springs and RCA's you will need adjustable control arms either upper or lower.
Car looks nice the way you have it though.
Old May 9, 2010 | 02:07 AM
SlowGS4's Avatar
SlowGS4
yea, im leaning towards df210 without front RCA. i didnt think my camber in the front would be that bad. the rear i want it to be a bit lower.
im running exact rca up front, i thought it was a 1" drop... adjustable control arms are too pricey for me. and thanks for the comment, i was hopping the rear would drop a bit more...
Anyone has their allignment spec lowered on df210?
Old May 9, 2010 | 02:46 AM
CK6Speed's Avatar
CK6Speed
Sage is 30mm, while Exact is 38mm.
Old May 9, 2010 | 07:22 AM
DarKnight's Avatar
DarKnight
You should actually probably use the rca's with the DF's, I have them on my car and the drop isn't even. There's more of a gap in the front than in the back. My car looks like yours but vice versa as far as the drop.
Old May 9, 2010 | 11:21 AM
SlowGS4's Avatar
SlowGS4
I was going for sage but exact had them in stock.
hmm any pictures of your car? along with allignment spec? how many miles you usually get out of your tires with this setup?
Old May 9, 2010 | 12:35 PM
GSteg's Avatar
GSteg
I thought you had D2 Racing coilovers?
Old May 9, 2010 | 08:50 PM
DarKnight's Avatar
DarKnight
I haven't taken any pictures lately, it's not picture worthy right now. I had an alignment done after the suspension install but I didn't get a spec sheet. The setup has been on my car since the end of last summer and I put winter tires on so i don't know yet how long the tires would last. I also haven't been driving the car much lately.
DarKnight's Avatar
DarKnight
I sold that setup a little while back. Decided to go with springs and shocks.
organicali
Suspension and Brakes
Oct 19, 2016 05:44 PM
Lightz2050
Jul 11, 2014 10:46 PM
stas2007
Jun 13, 2012 07:11 AM
Sheehan1p
26
May 29, 2011 11:54 AM
UptownGS
15
Nov 19, 2008 06:45 PM
