fuse and climate control problem:(
Old Apr 27, 2010 | 05:54 PM
gs300325ci's Avatar
gs300325ci
Default fuse and climate control problem:(
im having abig problem that i cant figure out. first of my climate control, mirror switch and inside light on the sealing stop working. so i figure i burned the fuse. i found 4 bad fuses with the tester, i took them out and they looked fine but i still got new ones and replaced them. the tester still shows that the new one in those sm pots are bad ones. cant figure out what is going on can ayon help maybe that had similar problem and how can ifix i since weather gettin hot hate driving with no ac
Old Apr 27, 2010 | 08:28 PM
gs300325ci's Avatar
gs300325ci
anyone with some tips or help
Old Apr 28, 2010 | 04:56 PM
gs300325ci's Avatar
gs300325ci
anyone?? please
Old Apr 29, 2010 | 09:28 AM
sakataj's Avatar
sakataj
first off the word is ceiling sir...
are you sure your tester isnt bad btw?
so your climate control assy, mirror switch and interior lights arent working?there's a fusebox underhood and in the passenger footwell also...dunno whats in them but manual should tell you maybe you have another fuse out in one of these? u have a volt meter? see if you getting voltage to these units....or take this to a mechanic if you dont think this is something you can do yourself. first step is getting power to these units...
Old Apr 30, 2010 | 06:08 AM
gs300325ci's Avatar
gs300325ci
out of all fuse boxes i only found 4 bad ones. andi replaced those 4 and the tester still shows that they are bad i guees ill have to take it to a mechanic
93Gotjuice
Feb 22, 2013 04:20 PM
mischief7
Sep 2, 2008 03:32 PM
YupImJOee
GS - 1st Gen (1993-1997)
Jul 24, 2008 10:48 AM
thinhthan
May 31, 2008 09:14 PM
joetek
Jan 28, 2008 04:02 PM
