seafoam
Old Dec 14, 2009 | 08:40 AM
  #31
aristo2369's Avatar
aristo2369
how bout on a 98 gs400? Can someone put a picture of the line needed to put the seamfoam hose?
Old Dec 14, 2009 | 09:09 AM
  #32
lexusscturbo's Avatar
lexusscturbo
96GS400 or 300?
Old Dec 14, 2009 | 01:39 PM
  #33
BP_VVt-i's Avatar
BP_VVt-i
SEAFOAM SUCCESS!!! wow that stuff is awesome n def work. my car wouldnt suck the seafoam up the pvc line so i poured it in wit a funnel and it did everything it was sposed to. i was scared for a minute tho becuz the car wouldnt start at first (u gotta keep holding the ignition) then it was dumb quiet for lyk 30 sec then i revved the engine n polluted my whole block. LOL n then drove off. hehehehe.
Old Dec 14, 2009 | 02:00 PM
  #34
aristo2369's Avatar
aristo2369
98 gs400......
Old Dec 14, 2009 | 02:05 PM
  #35
lilsharky's Avatar
lilsharky
do you have any pics of exactly where you poured it in to?
Old Dec 14, 2009 | 02:41 PM
  #36
memGS300's Avatar
memGS300
pics would help showing which hole/tube to pour into. Has anyone here tried Lucas Fuel injector in the gas tank and if so, how does it compare?
Old Dec 14, 2009 | 05:17 PM
  #37
lexusscturbo
This goes in direct via the injectors to the pistons..Works better than Lucas, I used 2 cans and doubled the dosage when i got my car with (47k)@ first....
As far as the guy with the GS4...Try removing the hose closest to the TB. You should feel strong vacuum.
And as stated before by me, after you let it suck in through the vacuum wait a good hour at least...Let it do its work.
Old Dec 14, 2009 | 07:54 PM
  #38
BP_VVt-i's Avatar
BP_VVt-i
Wish Granted. I took this from the other pic sum1 posted on here already
here's the step by step what i did for my 1999 GS300
1) separate the SeaFoam into THREE (3) small see-thru cups of if u want to measure it out be my guest. I jus poured sum each cup til the bottle was empty and there was equal amounts in each cup.
2) start your engine. the line i used wasnt getting much suction even while revving it at 2000rpms so i jus used a funnel
3) while engine is running disconnect the hose i circled that has number 1 pointing to it, ur engine will start to hickup and sound lyk its gonna cut off but it wont.
4) grab a funnel that's small enuff to fit in the tube so u dnt spill it lyk i did
5) when pouring the seafoam in this hose it goes directly into ur intake manifold, and after u get that 1/3 of the seafoam in there ur engine will stall out and cut off.
6) a little bit of smoke puffed out of my exhaust wen the car cut off, when it cuts off leave it off
7) now pour one of the 2 cups u have left in the crankcase (circled item number 2)
8) after that i poured the last cup into the gas tank (arrow 3 pointing off the picture lol)
9) then i waited ten minutes, sum ppl said an hour but mainly just let it sit for a minute
10) the last thing to do is to start it back up, it took a while for my car to start at first so jus hold the ignition down till it starts. wen it starts you will puff hella smoke. i started revving my engine so i culd get all the smoke moving out quicker. then a youttube vid sed u shuld drive around at high rpms. and of course since we have a mainly automatic cars so its kinda hard to get a high rev without the car shiftin g gears so i drove round in "3" for lyk 10 min and i was able to hold lyk 5500 rpms at lyk 70mph thru my neighborhood. and i left smoke clouds everywhere for lyk the first 10 minutes of driving. it was kinda cool. my car def runs a lot better and i will be getting an oil change 2maro.
Old Dec 15, 2009 | 12:56 AM
  #39
lilsharky's Avatar
lilsharky
thanks for sharing ^^ i have another question though, how many miles do you have on the car? I read that the main seals will leak after the seafoam because it cleans out the gunk that is holding it
Old Dec 15, 2009 | 10:12 AM
  #40
BP_VVt-i's Avatar
BP_VVt-i
my car has 115K miles on it and i kno bout the seals leaking. i had a friend who did that and his stuff came loose. but i checked all the bolts i'm good.
flash9
May 6, 2019 04:38 AM
step2me
Mar 2, 2014 09:27 PM
hazmat
Aug 21, 2011 10:10 PM
lex2001
12
Feb 1, 2011 02:21 AM
tritron
May 18, 2007 12:55 PM
