Got some riding low quetions
Old Sep 15, 2009 | 01:55 AM
gs400 civi's Avatar
gs400 civi
Default Got some riding low quetions
Hey does anyone use any kind of alerting system ?(especially for driving in new area's) besides scrape scrape along the ground that is. Also i was thinking about a splitter, installed to not protrude past where the bumper ends? extending from the fron to sa right after the cats or at least the space between the oil pan and the cats (like right at the curve of the exuahst). I'm thinking I hear the scrape scrape of plastic before metal. any suggestions would be great, i know riding low= scraping but I just want some more advance knowledge or something to maybe prevent disater-already failed once-car still in the shop
Old Sep 15, 2009 | 01:57 AM
5t341th's Avatar
5t341th
you hear plastic? all i hear is metal scrape. I see the exhaust as the lowest point on the car, and its stock. the only plastic i can think of that could rub is your fender liners. is it those?
Old Sep 15, 2009 | 03:04 AM
gs400 civi's Avatar
gs400 civi
no I hear metal, rear exhaust sometimes, but from the oil pan to the area where the pipes curve to go back is the most scetchy-poked a hole in my old gs's.
Old Sep 15, 2009 | 09:38 AM
vwynn's Avatar
vwynn
the only plastic that scrapes at the bottom of my car is the undercarrige cover or whatever.
Old Sep 15, 2009 | 10:46 AM
sakataj's Avatar
sakataj
engine skid plate
boooo mine ripped off when i was in atlanta and im not even lowered. thanks though to tony for allowing me to use his driveway and for taking it off for me
Old Sep 15, 2009 | 11:21 AM
AsGs300's Avatar
AsGs300
Hey Sakataj, did you ever replace that splash gaurd? mine ripped off too and now i can see the floor when i pop open my hood? not to mention the fenderliners have been ripped off! is it safe to be riding around with out all that plastic? Danm it sometimes i regret lowering my car!
Old Sep 15, 2009 | 01:30 PM
VNN326's Avatar
VNN326
that shouldnt be a problem riding that low, our GS's oilpan is way higher then our frame rails. its not a FWD where the oilpan will hang really low. your bumper should hit before the oilpan.
Old Sep 15, 2009 | 04:58 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
No it wont trust me on that its possible to hit the oil pan without hitting the bumper. I got a dent in my oil pan and my bumper never hit and I have the TTE lip. Got to adjust your driving style if you will be dropped, I live in NYC and driving aggressive here with a huge drop is not advisable. The thing with the GS is that the upper control arms in the front will hit the strut tower depending on your drop. If you are driving in a new area drive slow and learn to scan the road in front of you for anything that can damage your car. It takes practice and being very alert to drive super low.
Old Sep 15, 2009 | 05:06 PM
Rides Low's Avatar
Rides Low
Former Sponsor
Agreed, being alert is the most overlooked thing when driving low.
Old Sep 15, 2009 | 06:51 PM
[ant]'s Avatar
[ant]
yeah there is no cheat sheet- when going into new areas just look a long way ahead, be very careful, try to avoid anything that seems iffy...its a pita but thats driving slammed!
Old Sep 15, 2009 | 08:40 PM
EN_VY's Avatar
EN_VY
Agreed. You have to pay attention. When I first got air, I kept driving normal(fast) and I scraped alot. Its taking time for me to get used to driving slow(unless Im on the freeway)
Old Sep 16, 2009 | 12:33 AM
gs400 civi's Avatar
gs400 civi
well, that's exactly the kind of good advice i expected, but was hoping someone had come up w/ a solution, not just to be lazy, but night driving, long trips, other countries etc. think I'm gonna have to go w/ a fatty tire setup on the 19's to be safe, although I will have to see, some of the roads are exellent here and those are mainly the one's i've seen.
Old Sep 16, 2009 | 07:17 AM
JeffTsai's Avatar
JeffTsai
It would take some extra effort, but you can get a sheet of aluminum plate, cut and bend it to fit, and bolt it on under the car. Also the aerodynamic advantage of having the whole front of the car flat. This will keep most of the rocks and sharp objects from puncturing the oil pan. Now, if you bottom out the car very badly then it won't help you lol.
Old Sep 16, 2009 | 03:21 PM
gs400 civi's Avatar
gs400 civi
that's not funny jeff- maybe a lil, did you get my pm(s)?
Old Sep 17, 2009 | 12:41 PM
sakataj's Avatar
sakataj
i dont think he was kidding. its essentially adding some protection and aerodynamics to the car. kinda overkill but it all depends on what u wanna do. i personally want a rear diffuser but dunno if i will get one, hell i have to get a undercarriage tray again as i know i will lose some mpg on the interstate without having one
