first gen battery discharge behavior question
Old Apr 18, 2002 | 12:31 PM
cbc123's Avatar
cbc123
Question first gen battery discharge behavior question
The battery on my 1st Gen GS3 is drained if the car sits for 10-12 days or so. I believe the battery is fine. Question is: Is this normal? If so, what's the best way to stop it?
Thanks. -bruce
Old Apr 18, 2002 | 12:34 PM
blue wax's Avatar
blue wax
No this is not normal
you probably have an elec. leak somewhere.
yezzzzzzz
measuring will bring the answer.
Old Apr 18, 2002 | 12:49 PM
whitels's Avatar
whitels
Not normal. Two suspects- a case of a battery about to die, or electrical leak. In all likelihood, I would check the battery angle first. This is a classic sign when batteries are not able to hold a charge as long as it should - it means it is ready to die.
Can you switch battery with someone just to test? If not, check the specific gravity of the battery solution. This is a good indicator of the wellness of your battery. You can buy the tester from auto parts store.
Old Apr 18, 2002 | 05:10 PM
Jmai22's Avatar
Jmai22
take it to pep boys and ask them to check your battery. also check if your trunk light is turning off when you close the trunk. if not just take out the bulb
Old Apr 18, 2002 | 06:26 PM
concepts's Avatar
concepts
Bring it to any shop with a good snap on load tester.
It will test with the car off and then your charging system with the car on. 2 minutes.
keldon595
May 11, 2018 11:47 AM
doodlebug
Feb 9, 2018 05:39 AM
Bilque
Dec 12, 2014 05:33 PM
smackman
Oct 25, 2011 07:51 AM
cdvmagic
Nov 3, 2008 01:19 PM
