*****Caster Arms Replacement*****
Old Aug 29, 2009 | 09:06 AM
4uhaterz's Avatar
4uhaterz
Default *****Caster Arms Replacement*****
Does anyone have a write up on replacing these? I'm also lowering the car in the front so I assume it would be easier then.
Old Aug 29, 2009 | 09:41 AM
SoCalSC4's Avatar
SoCalSC4
All those asterisks in the thread title, but no clue about the search function?
This has been discussed 3,743,643 times.
Old Aug 29, 2009 | 09:54 AM
4uhaterz's Avatar
4uhaterz
You obviously have no positive information for this thread. Thanks anyways!
Old Aug 29, 2009 | 12:58 PM
SoCalSC4's Avatar
SoCalSC4
No charge for that. Anything else I can do?
https://www.clublexus.com/forums/sus...n-braking.html
I used the search function, it actually works extremely well.
Most of us have already replaced these. You can use the Daizen repplacement bushings or buy the entire new Lexus arm, like I did. They are fairly easy to install; plan on doing an alignment immediately afterwards.
You should definitely replace the lower ball joints at the same time, as these are a known wear item on these cars.
GS3KID
Suspension and Brakes
Mar 29, 2015 08:33 PM
subzero32
Apr 30, 2012 05:26 AM
Solo_D33A
Nov 18, 2009 12:39 AM
dongkeykon
Nov 5, 2004 08:54 AM
