How bad is stopleak for your radiator?
Old Aug 8, 2009 | 12:39 PM
augdogg's Avatar
augdogg
Default How bad is stopleak for your radiator?
I have a small rad leak and a new rad is a grip. Anyone use this before?
Old Aug 8, 2009 | 12:50 PM
GS300ToM's Avatar
GS300ToM
dont do it..... makes it worst IMO, ive seen many of people use this at my shop but ends up coming bak in a day or two haha
Old Aug 8, 2009 | 01:28 PM
geeznuts's Avatar
geeznuts
Dont do it! It will clog your system just save$$$ and buy a radiator
Old Aug 9, 2009 | 12:44 AM
skperformance's Avatar
skperformance
Buy a new rad , it is for use on crap boxes that you need to keep going.
It can clog the passages in the engines causing hot spots.
Old Aug 9, 2009 | 05:49 AM
BossGS4's Avatar
BossGS4
Aftermarket radiator is $100 .... JUST DO IT
Old Aug 9, 2009 | 07:49 AM
bugsyls's Avatar
bugsyls
come on its a lexus just bite down and get another radiator.......where you at in cali i know a place in fontana you might be able to get one used.
Old Aug 9, 2009 | 08:36 AM
schase's Avatar
schase
when i first got my lexus the fan put a lil hole in the radiator
i use stopleak and it work i even 4got my radiator even had a leak
so u can always use stopleak as a temp b4 you get a new radiator
Old Aug 9, 2009 | 08:38 AM
Rippaflow's Avatar
Rippaflow
Don't do it. Every mechanic I've dealt with has said no.
Old Aug 10, 2009 | 07:26 AM
augdogg's Avatar
augdogg
Really? Hmm where should i look for this price?
Hahaha easy for you to say, i just just put about 1500 into the suspension maintenance (not upgrades) and this economy isnt favorable. Dont even go to the pay/play scenario, cuz ive been in the game doing that for a bit and i generally do it right. Moneys real tight so imputs comments
Old Aug 10, 2009 | 09:02 AM
vwynn's Avatar
vwynn
sounds like a problem in a bottle to me.
have u tried temp fixing it from the outside?
Old Aug 10, 2009 | 09:20 AM
augdogg's Avatar
augdogg
pm'ed.....
Old Aug 10, 2009 | 09:21 AM
HI98GS's Avatar
HI98GS
A good radiator shop can repair the leak if the hole is in the radiator itself not in the end tanks. Then end tanks are plastic. The radiator, since it is aluminum or copper can be repaired quite easily.
Old Aug 10, 2009 | 09:43 AM
augdogg's Avatar
augdogg
good info! I should find that out! Thx...
Old Aug 10, 2009 | 09:52 AM
3UZFTE's Avatar
3UZFTE
As everyone else has said, don't use it, if you do, you will be not only replacing the radiator, but pretty much everything else that it comes in contact with, including a flush or two, just because it says "miracle in a bottle" doesn't mean it actually is one. As HI98GS said, most places can repair it, but with the aftermarket units being so cheap, don't lose sacrifice inefficiency for a few bucks.
Old Aug 10, 2009 | 07:19 PM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
aug come up to vegas and ill give you an OEM rad for 100 bucks ive got one chilling in the garage here for you
