Spark Plug controversy
I had my car in to a Lexus mechanic yesterday, and among other things, he said that "someone" had put the wrong plugs into the car (2001 GS430). Since that "someone" was me, I wanted to check with the community here.
I put in NGK BKR6EIX-11, which per sparkplugs.com, and the discussion here, seems to be a preferred plug. Yet the mechanic said they would use Denso SK20R11, which is original equipment item. He claimed that mine are the wrong heat range.
I suspect that he is used to the Denso's and automatically assumed that since mine were different, they were wrong. Or did I indeed put in the wrong plugs (or at least not the preferred ones)?
But I might go ahead and put in the Denso's next time around.
Secondly, The difference between the Denso and the Ngk plugs are the the Denso's are a long life plug where the Ngk's are a high performance plug. You won't get as long a life from the Ngk's but they will give better performance.
Anytime anyone from a dealership tells you anything take it with a HUGE grain of salt. 99% of the techs/service writers at dealerships don't know squat about anything outside following the service manual just like you or I could. They are there to make money plain and simple, you don't need to be any good to be a dealer tech, you just need to know how to read english. I'm not saying there aren't guys out there that are good techs at dealerships, but they are few and far between.
blanquitom
Apr 21, 2011 08:43 PM
