Eletrical Ghost........
Old May 15, 2009 | 08:37 PM
TomLee's Avatar
TomLee
Default Eletrical Ghost........
My car is starting to go haywire.
What happens is I can't control the windows from the driver side. If i press Right window down, nothing happens, but when I press the window lock down and up, the passenger window goes down an inch. To ge tit to go back up i do the same, press the window up, press the window lock up and down, then it goes up
When I open my door, the puddle lights/footwell/dome are on for a second, then they go off, when i press the window lock on then off again, the lights come back on.
Also while all this was going on a few minutes ago, it's taking a while to shift away from park. For example, before I could turn the key, press teh brake, and immediately shift. Now I turn the key, press the brake, the dash lgihts go from night to day mode and back, then it takes a few seconds, I hear a click then I can shift.
Grounding issue?
i reset the ECU but that didnt help.
Old May 15, 2009 | 10:28 PM
TomLee's Avatar
TomLee
Any input would be aprecciated. It seems as though the dash takes a few seconds to start up too.
Old May 15, 2009 | 11:25 PM
GS4_Fiend's Avatar
GS4_Fiend
You are going to need some wiring diagram for this. Some one upload it up for the guy.
Old May 16, 2009 | 12:34 AM
TomLee's Avatar
TomLee
It's ok i think. I traced teh electical problem to the driver side master window switch panel. Or whatever it is called.
When I dissconnect that unit, and turn the ignition on, everything is A O K. I think theres a malfunction, though i completely tore it part and saw nothing wrong. Could be a moisture problem since I do see lime erosion? similar to the stuff on batteries, on the ouside of the ciruitry... But anyhow its narrowed down to there.
I think what is happeneing is because of the malfunction, when the system is booting it runs into that problem, doesnt compute, freezes for a second then ignores it. No big deal for now, ill try to pick up another one soon.
BTW....looking at the tiny LED's on the circuit board. I dont think it would be hard to do a full car led conversion. It would just take ALOT of time and PATIENCE soldering on those tiny things. BUt i might have to try it soon, and be the first to have an all blue oem interior??
dredkam
Apr 11, 2018 05:53 AM
Zmon
Feb 11, 2016 04:28 PM
TorontoIS
Apr 9, 2012 10:57 PM
Bamadave
May 4, 2010 09:37 AM
mr29rose
Aug 20, 2009 06:29 PM
