Sage RCA install help!
Old Apr 13, 2009 | 02:52 PM
kit cat's Avatar
kit cat
Default Sage RCA install help!
So I probably should of looked this up before hand but I raised the car, loosened the two bolts to the lower ball joint, opened box and found two sets of washers.... and no instructions.
Where exactly do these washers go? One's a bigger one, and the other is smaller w/ a cut. I tried calling Todd and IMing him but no luck .
Old Apr 13, 2009 | 03:00 PM
GSteg's Avatar
GSteg
Take a picture
Old Apr 13, 2009 | 03:01 PM
kit cat's Avatar
kit cat
taking a pic, brb!
Old Apr 13, 2009 | 03:08 PM
CK6Speed's Avatar
CK6Speed
On the bolt, slide the smaller cut washer on first, then the larger washer. The larger washer should be sitting up right against the lower ball joint.
Old Apr 13, 2009 | 03:13 PM
kit cat's Avatar
kit cat
pics
CK6Speed>
so it's like....
that?
Old Apr 13, 2009 | 03:16 PM
sam430's Avatar
sam430
you got that reversed.
Larger
smaller
slide it in the sequence he mentioned. Make sure you torque it properly because it's a major connection. Tighten it evenly, initially, do not tighten so much until you have both bolts on.
Old Apr 13, 2009 | 03:20 PM
kit cat's Avatar
kit cat
yeah, apparently it's like this...
should have thought that one first...d'oh!
Thanks everyone!!
Old Apr 13, 2009 | 03:54 PM
GS FONZy's Avatar
GS FONZy
The smaller one is a lock washer for future referece.
Old Apr 13, 2009 | 05:23 PM
DASHOCKER's Avatar
DASHOCKER
Thanks everyone!!
I ordered these RCA's.. Excellent reference diagram! Are these compatible with the 01+ designed ball joints ..Do you have the 01+ ball joints Coco?
Old Apr 13, 2009 | 05:40 PM
PHML's Avatar
PHML
Master Thread Closer!!
I have 01+ ball joints...no rubbing issue...fitment is excellent.
Old Apr 13, 2009 | 05:43 PM
sam430's Avatar
sam430
it will work with all 2gs.
Old Apr 13, 2009 | 08:57 PM
kit cat's Avatar
kit cat
DASHOCKER>
lol, i'm an artist at heart . as everyone said, it should fit.
man, I've been working on these for hours now and only got about 1/2" of my coilover raised on one side... the freezing/thawing must have been put some stress on my coilover b/c the perch is NOT moving at all to the point I have to put a breaker bar on my perch.
Old Apr 13, 2009 | 09:38 PM
skperformance's Avatar
skperformance
FYI> spray some pb blaster and let it sit over night , also before moving the perch break out a tooth brush and clean the threads so you don't jam more dirt under it .
I live in the land of the salt and the snow.
Old Apr 14, 2009 | 12:15 AM
Chris4.3's Avatar
Chris4.3
Can you take a pic when your done? Im installing these soon. Thx
Old Apr 14, 2009 | 09:03 AM
kit cat's Avatar
kit cat
I sprayed the bejeebus out of it and also cleaned it up with a brush like you said but it was still really really stiff.
...too late, just dropped off the GS this morning at an alignment shop.
sorry man
