Darn Dealer!!!
Old Mar 17, 2009 | 06:34 AM
gs4play's Avatar
gs4play
Default Darn Dealer!!!
So I finally got off my lazy **** and decided to change my oil.. I couldn't start the car it sat in my driveway all winter. So I go to loosen up the drain plug from the oil pan, and was like hmmm why is the plug so loose. So when all said and done, when I try to tighten the plug it is stripped. The dealer did my last two oil changes, it just makes them seem guilty by not telling me as this is something I would have wanted to know. I mean I could have potentially destroy my motor if I was driving and the plug came loose. What do you guys think, I probably cannot blame it on them. I really do not want to change my oil again to add a +1 size plug. I am kind of ocd this is going to bother me every time I drive the car
Old Mar 17, 2009 | 07:28 AM
Alexus_300's Avatar
Alexus_300
If I were you, I'd go and get a new oil pan. They are only $90 new. While you're at it, pick up the black silicone RTV sealant to go with it. Total cost should run you around $110. Not hard at all to do really, it's just removing a bunch of bolts and then prying the oil pan off, then take a sharp edge and scrape the old RTV sealant off and reapply the new selant on the new oil pan and reinstall.
Old Mar 17, 2009 | 08:00 AM
GSteg's Avatar
GSteg
I recommend Toyota FIPG sealant. Hefty price, but it's damn one of the best stuff around.
Old Mar 17, 2009 | 10:03 AM
gs4play's Avatar
gs4play
Thanks for the advice guys.. However I just did my oil change, new brakes, and I want to slam the car.. and I am trying to buy a $165,000 home. Money is very very tight..haha I guess Ill just have to keep an eye out on the plug, but next oil change I will try and swap the pan, thanks!!!!
Old Mar 17, 2009 | 10:30 AM
kamlung's Avatar
kamlung
ever consider one of these? i have them on my Acura... they work great...
http://www.fumotousa.com/
Old Mar 17, 2009 | 10:39 AM
sam430's Avatar
sam430
I always thought about doing that but never get to doing it.
Old Mar 17, 2009 | 12:30 PM
sakataj's Avatar
sakataj
that actually looks interesting....
Old Mar 17, 2009 | 12:37 PM
gs4play's Avatar
gs4play
hmmm, it may work but if my threads are stripped, which I believe them to be, then it probably will not work. I did read a little more, it is suppose to fix stripped threads.. wohoo!!
Old Mar 17, 2009 | 06:54 PM
gsCrazy's Avatar
gsCrazy
i have my fumoto plug for sale if anyone wants. i had it on b/c i used to change my oil very often (i drove 100 miles to work each day). i don't change the oil that often anymore and took the valve off. it is perfect condition.
Old Mar 18, 2009 | 05:21 AM
Sydwayz's Avatar
Sydwayz
I can't remember as I've only changed the oil on my GS300 once, but is the drain plug on the bottom of the pan, or the bottom? If it's on the bottom, the Fumoto valve will be hanging down and a little too vulnerable for my taste, especially if you are lowering your ride. If it's on the side, you are going to leave perhaps 1/4-1/2" of old oil in the bottom of the pan due to the way the drain valve is positioned.
I have a Fumoto on my Ford Dually 4x4 and had one on my G/F's Firebird before I totaled it due to an a$$hat crossing the center line.
They do work very well, but just be aware of the disadvantages.
Old Mar 18, 2009 | 10:53 AM
sakataj's Avatar
sakataj
how much?
yeah i thought about it possibly being to low especially if your lowered didnt consider other one though. good points
Old Mar 18, 2009 | 12:44 PM
PHML's Avatar
PHML
Master Thread Closer!!
Is the drain plug bolt stripped...or the drain plug opening?
Old Mar 18, 2009 | 12:53 PM
BossGS4's Avatar
BossGS4
If your drain plug is loose then the oil pan itself is stripped. The Fumoto Valve is not going to fix your FUBAR'd threads.
The only fix, besides replacing the pan, is going to be drilling (yikes !) the hole and tapping for a larger drainplug. I would DEFINITELY use a drain plug rubber washer or copper crush washer as well.
You might be able to Helicoil the threads but I don't know if there's enough 'meat' in the wall thickness of the oil pan for a Helicoil to work.
If this is your daily driver you might want to suck up the cost of the new oil pan otherwise you could drop the plug, seize the engine and you'll be shopping for a $155K house !
Old Mar 18, 2009 | 02:12 PM
augdogg's Avatar
augdogg
Car maintenance is super e-z and way cheaper to diy. Erryone should at least know the basics (i.e. oil change, tune-up, brakes, etc...)imo. I would say do every and/or all your own installs, cuz it just makes you more familiar w/ your car + save much hard earned $$$.
stlgrym3
Feb 8, 2015 06:39 PM
dsc07
Jan 8, 2014 08:27 PM
Mazenm
Feb 11, 2010 10:36 PM
actuary
Feb 2, 2007 06:34 PM
Captain57
Jun 28, 2004 01:05 AM
