smoke from cat
I was driving fairly hard for about 5-10minutes. I got to my friends place and we notice smoke coming from the hood
. I didn't want to open the hood b/c who knows what could have happened in there....so I looked underneath the car and I have smoke coming out of my catalytic converter on the passenger side (I have a GS400)
. I opened the hood later and everything looked fine from above the engine.Has anyone had this before? I do have a P0161 I've been putting off (bank 2, sensor 2 O2 sensor) so I'm thinking that's the culprit... any insight is welcome.
TIA
If you have been running super rich for a long time you may have damaged your cat, if that's the case it will need to be replaced. Probably don't want to put that off as you could quite easily start a fire if not addressed.
I and a few others have had the same problem.
Before you go crazy lift the car up and make sure the oil filter is tight. If its not, like it happened to me, as you are driving oil will leak and fly all over the exhaust making it smoke.
hope this helps
hope this helps
flyboyplo
May 9, 2014 08:30 AM
KingNasGS4
Jun 22, 2010 08:34 PM
