000, Lexus, Gs300, Intake Installation, Prob!help.
Old Feb 17, 2009 | 10:46 PM
vvti6's Avatar
vvti6
Default 000, Lexus, Gs300, Intake Installation, Prob!help.
Hello. Thank you for taking a look at my post. I bought a new intake and installed it how I usually do to other cars. but this one is giving me Problems. there is one tube that does not have a place to be plugged in to so I put an oil breather on it. that did not solve the problem. When I took it for a spin at first it wants to stall, but later it just gives revvs but it feels like half of the horsepower is cut off
Old Feb 19, 2009 | 02:19 PM
Euro09's Avatar
Euro09
and where is that one tube u talking about ?? I see all the tube are plug in already ?
Old Feb 19, 2009 | 03:45 PM
VNN326's Avatar
VNN326
i had the same problem, just head to your local home depot and get a T connecter for hoses, and connect it. the bottem hose should be for your gas tank to relieve presure. GL.
Old Feb 19, 2009 | 07:55 PM
Infamous 1's Avatar
Infamous 1
Do you have pics of what you are talking about?
Old Feb 19, 2009 | 09:23 PM
Hectorm's Avatar
Hectorm
Traction control is off?
Old Feb 19, 2009 | 09:32 PM
kevin.tran's Avatar
kevin.tran
Buy the T connector and connect three of the hoses together. So you'll have one running from your intake to the T connector and than the t connectors to the other 2 hoses. Thats how I did mines. Never had a problem. I don't think the breather will work because that hose isn't sucking up any air. When your intake is sucking up air it forces air into the hoses and I think that's how air gets into those hoses
Old Feb 19, 2009 | 09:55 PM
Alexus_300's Avatar
Alexus_300
The hose that you have a breather on should sense vacumn pressure. So you need to attach it to somewhere where there is a vacumn pulled at all time.
Old Feb 19, 2009 | 09:56 PM
SorrGwa's Avatar
SorrGwa
there should be a total of 3 hoses to attach, i see only 2 hoses attached. so like everyone said, ur gonna have to run a T connector so that all 3 hoses are attached again.
Old Feb 19, 2009 | 09:57 PM
VNN326's Avatar
VNN326
its pretty self-explanitory. 1 goes into the intake the other two just goes on the sides.
Old Feb 19, 2009 | 10:05 PM
GS4_Fiend's Avatar
GS4_Fiend
The hose with the black color does not need to be plug to the intake. You can simply remove that black hose and plug it with a rubber plug. That should fix the weird idle problem.
Old Feb 24, 2009 | 10:29 AM
Euro09's Avatar
Euro09
[QUOTE=vvti6;4264766]Hello. Thank you for taking a look at my post. I bought a new intake and installed it how I usually do to other cars. but this one is giving me Problems. there is one tube that does not have a place to be plugged in to so I put an oil breather on it. that did not solve the problem. When I took it for a spin at first it wants to stall, but later it just gives revvs but it feels like half of the horsepower is cut off
QUOTE]
Did you solve that problem yet ??? mind to tell me where did u get that intake ? I want one like that too.
btsman
Performance
Oct 29, 2018 12:05 PM
itztwinki3
Sep 11, 2014 08:57 PM
