Lugnuts and Spacers
Old Jan 28, 2009 | 12:35 PM
samster16's Avatar
samster16
Default Lugnuts and Spacers
I got two scenarios here and I need some help from fellow CL members.
1) I am currently riding on stock 16s, and I am about to put on the stock 17s on my car. Will I need new lugnuts? What's the difference between the two?
2) If I get 25mm H&R trak wheel spacers, would I need new lugnuts as well if I put the 17s on?
I tried searching for the two, but not too much info on lugnuts.
Thanks in advance.
S
Old Jan 28, 2009 | 12:37 PM
GSteg's Avatar
GSteg
You can reuse the lugnuts. However it's the stud that needs to be replaced depending on what spacers you get. Normally they include the studs.
Old Jan 28, 2009 | 12:48 PM
Caoboy's Avatar
Caoboy
If you get the 25mm(like adapters) and they have the studs already in them, you'll be fine. I think anything smaller than 20 or 15 you have to replace with longer studs. Lugs will be fine.
Old Jan 28, 2009 | 01:21 PM
SorrGwa's Avatar
SorrGwa
lug nuts generally go with type of wheel you have.
my stock 16s use shank style lug nuts, my aftermarket 20s use tappered lug nuts.
i went with a smaller spline drive nut w/ key so that i run less chance of accidentally scratching the rims when taking them off.
as for spacers, u got regular spacers (which require longer studs if they are more than 5mm), or spacer adapters with new studs on the spacers (requires wheels that have the right type of back hub to be able to use these in case the stock studs are longer than the width of the spacer adapter.
which trak spacers did you get? did you get the DRSs or DRMs?
the DRSs are more like the traditional spacer, which u need to press in new studs if u are running 5mm or wider. the DRMs are the spacer adapters discussed above.
DRs and DRAs are meant for euro cars.
Old Jan 28, 2009 | 02:16 PM
PHML's Avatar
PHML
Master Thread Closer!!
No...use same lugnuts.
No...use same lugnuts if using OEM 17s on longer studs.
Old Jan 28, 2009 | 06:07 PM
BCP43002's Avatar
BCP43002
I have stock 5 spoke 17's and my snows are on stock 16's. I use the same stock lug nuts for both.
Old Jan 28, 2009 | 06:26 PM
LeXaNoMicS's Avatar
LeXaNoMicS
i get new lug nuts with every oil change
Old Jan 29, 2009 | 10:01 AM
samster16's Avatar
samster16
Understood.
I haven't picked up my spacers yet, going to wait til the cold weather is gone here on the west coast then do everything at once. Lowering it with L-tuned, throw on the wheels, and add the spacers.
Will post pix once i am done (although it wouldn't be anything crazy).
Old Feb 2, 2009 | 09:22 AM
MPLexus301's Avatar
MPLexus301
Searched and found this thread which seems to have good info.
I have the stock 5 spoke 17"s on my car and was wondering what spacer kit would be best to push the front and rear wheels just out to the wheel wells. I don't need anything aggressive, but just out so that they are flush with the car.
Thanks
soleeasii
Aug 11, 2015 01:54 PM
fr0st
May 4, 2010 10:18 AM
mxis350
Feb 26, 2010 07:12 PM
mad_trbo
GS - 1st Gen (1993-1997)
Dec 28, 2008 11:09 PM
