Intermittent Air Conditioning Problem - 98GS400
Old Jan 26, 2009 | 03:22 PM
AZGS4's Avatar
AZGS4
Default Intermittent Air Conditioning Problem - 98GS400
The air conditioning on my 98 GS400 works about 90% of the time, but ocassionally when I turn it on it doesn't work at all. No fan...nothing. When I switch it off and then on again it works...although I have to sometimes do the on and off thing a few times in a row before it will work.
When it is working, again 90% of the time, it works great.
Any ideas what could be causing my intermittent problem?
Old Jan 26, 2009 | 03:44 PM
Kbueno's Avatar
Kbueno
Does the auto button light up when you turn it on? bad switch?
Old Jan 27, 2009 | 12:34 AM
dwoods420's Avatar
dwoods420
I have the same problem.
Old Jan 27, 2009 | 07:33 AM
AZGS4's Avatar
AZGS4
I will check next time I am having the problem. The auto button lights up and functions when the air conditioning is working. I don't know if I have tried auto in the past during one of the times it wasn't working.
Old Jan 27, 2009 | 08:36 AM
LEXUS_KID's Avatar
LEXUS_KID
I would check the fuse or relay
Old Jan 27, 2009 | 02:42 PM
AZGS4's Avatar
AZGS4
Thanks for the suggestions. If it was a fuse I believe the problem would not come and go. It would either work or it wouldn't work.
The relay may be something...any idea where it is and how to check it?
Thanks.
Old Jan 31, 2009 | 11:58 PM
GS4_Fiend's Avatar
GS4_Fiend
Bad switch
Old Feb 2, 2009 | 09:22 AM
sakataj's Avatar
sakataj
+1 either bad switch or bad relay
Old Feb 2, 2009 | 09:40 AM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Defective switch/relay ,wiring harness issue to blower motor,dead spot on blower motor resulting in it not kicking on. If you have access to borrow someones a/c control unit test it out best way to see if you need to replace the control panel. Make sure no rats have made a nest in your a/c system and chewed some of the wiresto the blower motor. I see that all the time and they chew all kinds of things in the car other then that. Good luck!...
Old Feb 6, 2009 | 03:15 PM
AZGS4's Avatar
AZGS4
I'll check my wiring..I did have some rats in the engine bay the other day.
A/C has been working perfectly since my first post. Maybe a good jinx?
Old Mar 16, 2012 | 11:48 AM
AZGS4's Avatar
AZGS4
^^^ Three years later and my A/C is still working without any further problems. Not sure what the issue was, but it seems to have 'fixed' itself.
blilker
Nov 8, 2013 11:20 AM
dseag2
Oct 7, 2013 04:53 PM
0nePutt
Dec 10, 2008 12:17 PM
Sammzway
GX - 1st Gen (2003-2009)
May 8, 2008 11:51 AM
nnnickkk
Jan 19, 2006 05:34 PM
