K2 Hid 8000k
Originally posted by Skulinex
WOW, they look awsome dood!, now I have an idea of what they will look like.. one question though, are you using D2S or D2R bulbs??, just wonder that, but I really like their color
i hope it helps, if you need more detail i can provide with it later, write here if you need them
Originally posted by CamRen
ouch..... the pictures are blinding me and giving me color spots .....
and im not kidding.....
those bulbs are nice and bright and blue!!!
you wanna see some purple???
drive up to a building w/ tinted glass widows... and see the refelection on your hids in them ... its bluish purple... haha just another way to see yours hids how the others see em on the road...
Enjoy em!
Cya
Enjoy em!
Cya
Originally posted by TXSTYLE
When I go to K2's website I don't see any "8000k" bulbs?!
Just 6000k! I too want a whiter bluer light as opposed to our more "violet" color beam!
i never been on their website
i can hook you up with 8K if you want
"violet"
Originally posted by BADGS400
those look extremely good!!!!!! Ill have to be gettin them? (8000K or not) i like em, do all of them look that way around 6-8k or are yours different from most others? Hope you enjoy blinding people
i'm sorry i dont understand your question, refrase is so i can answer it
and thank you for blinding others
Originally posted by SandRock
They have a whole bunch of them (K2 HID 8000k with Phillips ballast) on ebay. They keep saying they are new and not at retailers yet. One ad said they are going to retail for 1k.
a1lexus, those hids look pretty good from those pics. You said you didn't need to install any wiring. Well, you dont need to, but it's a very very good idea to wire in an automotive relay switch from your ballasts. If your GS didn't come with hid oem then it wasn't designed to power the ballast. The hid ballast is an ignition box filled with dozens of capacitors and resistors that charge up a 50,000watt discharge. A totally different powerplant from boring halogen bulbs. Just a plug and play install will put a lot of strain on your alternator and the relay neutralizes that by tapping power off the battery.
The different coloration of an hid system is determined by two factors: bulb element and optics. A 6000K bulb is blurer than a 4000K bulb of course. Also the optical lens system will determine color by breaking down the white light in certain ways. This is why the Honda S2000's lights flicker blue, red, purple, pink when the car pitches up and down. Every hid factory-equipped car comes with 4100K bulbs. Yes, even BMW, Audi, Mercedes, Lexus, Honda, all are 4100K. And I guarantee you due to optic lenses, some will be bluer or more colored than any hid kit you can buy on the market no matter how falsely advertise they may be (ie 8000K or 12000K).
Once again, 8000K light bulbs do not exist, this is a marketing ploy. The e-bay peddlers are talking out of their asses when they say they have a product that isn't on the market yet and are selling them for over 50% off. Does anyone else here find that HIGHLY SUSPICIOUS??
The D2R bulb is used in reflector beam lamps and the D2S is used in projector beam lamps. You can tell which is which by looking along side the bulb itself. The D2R bulb has a dark band painted along the side alledgedly to reduce difraction outside the beam pattern. The D2R is an older technology and most cars are using the projector D2S bulb, except for Mercedes--they want to differ from BMW. If you bought an hid kit, you want the D2S because D2R will only reduce light output. You can 'convert' a D2R to D2S by taking fine sandpaper and rubbing the strip off gently.
K2 kits don't come with Philips ballasts. They come with a unmarked, unlabelled Korean-made ballast, which is totally different in terms of build quality from Philips. Philips is one of the top notch industry best---so much so that there are actually Philips knock-offs.
Just touching on a few points I saw on the thread. a1lexus, pics from afar would be good. Your hids look good. I was afraid they might be too purple---any K2 buyers, don't buy the 'Crystal White' kit. It is waaaay too purple.
Ok ill say it differently, i might be gettin some... i really like them, do all the HIDS from 6000 to the "8000" look the same color as yours, or are yours different from most of the other, or all the others?
the hope you enjoy blinding people is a joke incase you didnt know
hope you understand this...
50,000 wats discharge.. that's happens only once when you turn lights on, then it goes to 35wats
"Oh, I have factory installed HID, and none of those non-factory stuff, even though it might be better"
those are 8K, not a 6K, i'm looking at the kit right now and everywhere it says 8k, this is *retail* kit not just white box.
but if i answer and that's not exactly what you looking for send me an either email or PM with text in your native language i'll try to translate
as for your question:
i belive that 6000k will turn to "yelowish" after while but will start from blue, only 8000k will stay blue all the time
i have not seen any other 8k out there.. they just came out.. maybe a little bit over a month or so
Originally posted by a1exus
I don't know man, sounds like you have factory and you d-a-m-n proud of it, 'cause you you can read it between lines in every post that you left:
From your pics I can see more that they are not 8000k in color compared to the 6000k bulbs I had before. That's why everything is kinda fishy. If Phiilps release some sort of 8000k bulbs in the future, I wouldn't be surprised to see K2 8000k bulbs disappear. I don't think anyone other than Phiips or PIAA can develop 8000k bulbs before them.
Again just watching out for you man. It'll SUCK if you got something that you think is right but is not.
i'm going post few pictures how exactly everything is connected, yes this is true it didn't required any wiring, it has connectros where you plug everything in without cutting any wires, that's what i meant no wiring.
all cars comes with 4k that's true, but then again.. i'm not quite sure about new cars.. like years 2002 or 2001 or even 2000 might come already with 6k, since this technology was out for while already, it's quite possible that they can deside to upgrade their 4k to 6k
You've seen the marked improvement from halogen to hid and I congradulate you on that, honestly. Next you'll see the marked improvement from hid to factory hid. A benchmark of hids isn't in staring directly at the low beam and saying "Ooo, that's bright! Much brighter! Bright is cool!". Brighter isn't even neccessarily better, most of the time it just mean higher farad capacitors that reduce bulb life. Check the beam pattern, the cut off, etc. Compare your hids to the RX300 hids, which have very sharp distinct lines.
um.. thank you for explaining what's the difference between D2R and D2S..
what makes you think so? my ballasts the came with this kit are made by philips.
will post them soon..
And as the halide crystals vaporize over time, the color temperature will shift to the warmer end of the spectrum as this is the case with all metal-halide arc lamps.BTW color is also determined by the type, mixture and quantity of xenon gas (which is used to start the arc hense the initial deep blue) and halide crystals and mercury, the more xenon, the bluer the light will appear.
Wattage is a resistive load
50,000 is a lot most I have seen have ranged from $20,000-25,000 volts
Originally posted by jahummer
You could use a color temperature meter to find out
The yellow is halide crystals
