Engine Help 2JZ-GE
Old Oct 16, 2008 | 03:02 PM
jcat_350's Avatar
jcat_350
yes, it will bolt right into the 98+ gs. No, you should swap the auto tranny onto the engine for ease of install and avoiding a bunch of headaches such as wiring, ecu's etc.
Old Oct 16, 2008 | 03:10 PM
1989Lexus's Avatar
1989Lexus
So the engine will work with the automatic transmission?
GS300Jason's Avatar
GS300Jason
I think you might need to do some machining on the GE tranny for it to work with the motor. I am not 100% sure.
And yes, I am quite aware that Supra's also came with the 2JZ-GE.
Old Oct 16, 2008 | 03:49 PM
1989Lexus's Avatar
1989Lexus
okay thanx....
Old Oct 16, 2008 | 05:50 PM
ElitistK's Avatar
ElitistK
Wow went through the first page and nobody posted something meaningful
Your supra's 2jzge is rear-sump, and our cars have front-sump oil pan. You're going to need to change that. It's not difficult, but it's not cheap if you're not doing it yourself.
Also, you will need to use the gs harness and ecu to make it work.
It doesn't matter if the ge was mated to a manual or auto, it will bolt up without issues.
That's about it. For all this trouble you could just go with an aristo gte or build your blown ge.
Old Oct 16, 2008 | 06:22 PM
1989Lexus's Avatar
1989Lexus
^ so do you suggest?
Old Oct 16, 2008 | 06:23 PM
ElitistK's Avatar
ElitistK
i suggest finding another 2jzge from an is/gs for the most cost efficient route.
but for the most efficient performance to cost ratio, an aristo gte is the way to go . It will definitely renew your love with your gs after something like this has happened.
Old Oct 17, 2008 | 07:21 AM
1989Lexus's Avatar
1989Lexus
I dont even have a 2GS. I own a 3GS. I just happen to aquire a 2jz-ge block with 11k miles on it from a 98 Supra. What to do with it? So I was thinking is it worth putting it in a 2GS? It only has 11k original miles on it. Should I not bother?
Old Oct 17, 2008 | 08:01 AM
fatmike's Avatar
fatmike
Damn Jay so you just have a motor sitting around?
Old Oct 17, 2008 | 11:28 AM
1989Lexus's Avatar
1989Lexus
^ yeah..... maybe mike needs it? lol
Old Oct 17, 2008 | 11:48 AM
ElitistK's Avatar
ElitistK
put it in your 3gs and slap a turbo on it. instant win.
Old Oct 17, 2008 | 11:53 AM
jcat_350's Avatar
jcat_350
+4645858785949574756
Old Oct 17, 2008 | 12:10 PM
1989Lexus's Avatar
1989Lexus
No thanx.. I need the AWD for the winters here.
Old Oct 17, 2008 | 02:44 PM
1989Lexus's Avatar
1989Lexus
anyone konw how much this engine would be worth?
Old Oct 17, 2008 | 02:56 PM
ElitistK's Avatar
ElitistK
$500 bux give or take w/ an ecu.
Hussaings
Jul 18, 2015 07:52 PM
TestIS
Performance
Dec 3, 2010 05:13 PM
FL1PP3D
Aug 26, 2007 02:59 PM
ballin
Lexus Vehicles Classifieds
Jul 29, 2007 01:34 AM
