A/F question
Old Oct 6, 2008 | 08:20 PM
fordsvtmfl's Avatar
fordsvtmfl
Default A/F question
is there a way to adjust the A/F ratio in the Gs3 without a A/F controller? like if i had a A/F gauge and saw it was running too rich or lean...would i not be able to do anything about it without a controller?
Thanks
Old Oct 6, 2008 | 08:51 PM
[ant]'s Avatar
[ant]
^ yep cant do anything. need the controller. its all done by the ECU and the controller intercepts the signal allowing you to manipulate what the ecu does for fuelling
Old Oct 7, 2008 | 07:50 PM
GS FONZy's Avatar
GS FONZy
There is no reason why the fuel trim will change, unless there is something wrong with the car. Also, how will you be reading you A/F ratio? The short band is not an acurate way to read A/F ratios anyways.
Aswilley
Jun 6, 2014 03:39 PM
boosted-gs
Performance
Aug 30, 2007 06:36 PM
GS FONZy
Performance
Jul 14, 2007 07:07 AM
DrRick
Performance
12
Nov 22, 2002 06:08 PM
Hermosa
Performance
Feb 12, 2002 12:19 AM
