Another question for the wheel gurus...
I am thinking of picking up a set of works. Right now I am just on springs, no other suspension mods.
19x8.5+25 (clear big caliper) 19x9.5+35 5x114.3
The other set is 19x8+38 19x8+36, but I would like to put the biggest tire on possible to keep traction. I dont mind rolling/cutting the fender lips.
Will that fit?
I have 225s for front and 245s for rear.
Thanks in advance!
Will that fit?
Thanks in advance!
Will that fit?
Thanks in advance!
Will that fit?
Thanks in advance!
I had a set of scaras that were 19x9 +29 and 19x10+35 and had no issues. I was on 235/35 and 275/30's
Have you used the 1010 offset calculator?
http://www.1010tires.com/WheelOffsetCalculator.asp
225 and 245 is not the widest you can have. I would go 245 and 275, but you might have to trim the fender if you don't want to rub.
What are your plans for the car? If you don't have many mods, why are you concerned about traction? The first thing you must eliminate is body roll, then work from there. IF you are interested in traction for launch, then look for an LSD.
That's kind of a weird offset combinaton.
The fronts are fairly aggressive, but not overly so.
They would sit on the fender the same as 19x9 +31
The rear are actually kind of conservative and will only sit out 3mm
further than the fronts. Would look the same on the fender as
19x10.0 +41 or 19x10.5 +48
You'd need a spacer on the rear to get them anything resembling "flush."
For perspective, my FRONT wheels are more aggressive than those rears.
This man knows @@@@!!!!
He is probably looking at used wheels. Got to work with what you can get.
all four corners of a 2GS, the rear wheels are buried about 1" (25mm) more than the front.
Look at the stock wheels on a GS. The rears are lost!
Because the new wheels basically have the same frontspacing front & rear,
the front wheels will be fairly aggressive on the fender and the rears will
be more tucked.
A 20-25mm spacer would flush the rears up a bit.
I'm a little confused by this statement... in my experience, if you use the same wheel on
be more tucked.
be more tucked.
trinityhk
Mar 15, 2008 10:29 PM
