Rear spoiler
Old Sep 9, 2008 | 03:33 PM
RI-Lex's Avatar
RI-Lex
Default Rear spoiler
Ok, guys I will like to get rid of my oem rear spoiler at some point, is there any spoiler out there that cover the trunk holes without some body work? and no I can't see the add of someone trading trunk lids with me, since my car color is hard to come by now adays burnished gold. HELP
Old Sep 9, 2008 | 03:51 PM
jcat_350's Avatar
jcat_350
I don't know if there are any, but the 3-piece i think maybe RMM? should cover them. I'd suggest a lip spoiler but they don't really cover too much of the trunk lid.
Old Sep 9, 2008 | 03:53 PM
RI-Lex's Avatar
RI-Lex
If someone can confirm that the RMM is good for sure, I'll be on the hunt for one.
Old Sep 9, 2008 | 03:59 PM
jcat_350's Avatar
jcat_350
here's the pic i'm thinking of, seems like the top part extends to about where the OEM spoiler mounts...
Old Sep 9, 2008 | 04:02 PM
garbage85's Avatar
garbage85
junction produce wing should solve the problem
Old Sep 9, 2008 | 04:08 PM
chrispy's Avatar
chrispy
If I remember correctly, the Win Sports spoiler covers the holes. But I would just do it right and get it shaved and repainted. If you leave open holes rust could develop even with a spoiler covering it up. Plus the no spoiler look is nice.
Old Sep 9, 2008 | 04:35 PM
shvc1991's Avatar
shvc1991
I too plan on replacing the OEM spoiler... It rattles like hell when I turn up the music.
3pc JP spoiler... Here I come!
Old Sep 9, 2008 | 05:45 PM
phillygs3's Avatar
phillygs3
thats like putting a bandaid on a knife wound. get it done rite fix the holes first
Old Sep 9, 2008 | 07:05 PM
shvc1991's Avatar
shvc1991
Could anybody explain why this is such a bad thing to cover up the holes?
Old Sep 9, 2008 | 07:07 PM
huddleston's Avatar
huddleston
JP will work for sure.
Old Sep 9, 2008 | 07:12 PM
jcat_350's Avatar
jcat_350
they will more than likely rust out even if covered by the spoiler due to condensation etc. and the insides of the holes are not coated, they are just exposed metal therefore even faster rusting.
Old Sep 9, 2008 | 07:26 PM
phillygs3's Avatar
phillygs3
Ri-lex from looking at your sig looks like you put alot of money into your car trust me get them holes fixed first
Old Sep 9, 2008 | 07:44 PM
[ant]'s Avatar
[ant]
i guess it could work if you didnt want to repaint the boot just get the spoiler painted and stuck on. You would just need to make sure you prep and paint any exposed metal edges so they're sealed, and then use plenty of sealant to attach the new spoiler so that no moisture can get under it.
i have to repaint my boot anyway because i have a streak of something running down under the clear coat at one side of the boot.. probably some moisture under there i guess
Old Sep 9, 2008 | 09:08 PM
ak11's Avatar
ak11
I will silicon the holes with paintable silicon, let it dry, cut the extra. Touch up with paint, Wet Sand, Polish gentlely. Hopefully the silicon will not drop into the hole...
I can take your old spoiler if you dont want it Free....!
Old Sep 10, 2008 | 12:11 AM
[ant]'s Avatar
[ant]
^ there is no point filling with silicon really if he is going to cover it with the new wing provided he adequately seals with sealant. he could probably put a rubber stopper on the underside of the boot and silicon that in too, just to seal it up. But if there is plenty of sealant (e.g sikaflex) right up to and around the edges of the left over holes then it should be fine..
