Unusual Problem
Old Jul 16, 2008 | 02:46 PM
Lamchop21's Avatar
Lamchop21
Default Unusual Problem
Most people manage to lose their keys and end up buying a blank key, cutting it, and programming it themselves. My problem is a little different. Don't ask how because I don't know, but I have managed to lose the chip inside the shell casing. I can still open my doors with the key but I can't start the car because I don't have the chip. Is it possible to just get the chip for our cars? And if so, does anyone know where to get one?
Old Jul 16, 2008 | 02:57 PM
farkas's Avatar
farkas
You can go on Ebay and buy a used key for your type of car rather cheaply, then take the transponder out of it and put it in you key blank. Then you will have to program it to your car. There are posts on here on how to do this. Also if you PM me I will share with you a site that specializes in Lexus and Toyota keys and remotes and they will tell you how to do it or they have the instructions posted on their website. It worked for me!
Here are the instructions from their website on how to program up the key for a 2000 GS300....
The important thing is to get the correct Chip(Transponder) for your keyblank.
Lexus Key and Remote Programming
Key Programming
1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming
1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove. Do not turn it on.
3. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
4. Close and open drivers door.
5. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
6. Put key into ignition. Turn to "ON" , turn off and remove.
7. You will see the door locks cycle by themselves.
If the door locks do not cycle (lock and unlock) by themselves then the car isn’t in programming mode and you must start over.
8. On the remote, press and hold the LOCK and the UNLOCK button at the same time for no more than 2 seconds.
9. On the remote, press the LOCK button for no more than 1 second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted.
IF the locks cycle twice it has failed.
The most common reason for programming failure is because the car didn’t receive a good signal from the remote. To fix this problem try these tips.
1) Stand outside of the car while you are performing steps 8 and 9.
2) Don’t hold the remote buttons down as long.
As long as the car is still in programming mode you can keep trying steps 8 and 9 until you complete the programming. If you wait too long and the car exits the programming mode then you must start over.
After you get the remote to program then continue on with step 10.
10. Close and open door to end programming procedure.
Old Jul 17, 2008 | 12:43 PM
400PR00F's Avatar
400PR00F
Unhappy
Wait,wait,wait...so the blades won't be the same?? I was thinking of taking this route to get a spare key b/c I bought my car from a dealer who kept the spare (for obvious reasons). I thought all I had to do was get one of those keys off Ebay, program it, and get a beer...
Old Jul 29, 2008 | 03:34 PM
farkas's Avatar
farkas
In your case you also need to purchase an uncut keyblank and have it cut by a locksmith or dealer. Lamchop21 has the blade already, they only needed the transponder.
Old Jul 29, 2008 | 03:37 PM
pingu's Avatar
pingu
I hope that wasn't your only key. If thats the case you cant reprogram a remote.
Old Jul 29, 2008 | 03:49 PM
farkas's Avatar
farkas
As long as you have a Master key available, you can reprogram the keys remote. The Cars computer will pick up the new remote keys transponders ID code and add it to its list. Also once you get into programing mode, you can completely wipe out that list and start fresh but I have yet to find someone brave enough to try it!
Old Aug 4, 2008 | 07:26 AM
sakataj's Avatar
sakataj
do i even wanna ask how you did this?
HOLGER21
Mar 25, 2017 07:49 PM
MattUK
Jun 11, 2016 01:22 AM
dwolsten
Jan 25, 2013 04:49 PM
TexasDave
RX - 3rd Gen (2010-2015)
37
Jan 31, 2012 03:11 PM
ot180
Dec 7, 2004 07:14 AM
