Oil leak sorrows
Oil leak sorrows
This is really putting me down in the dumps. I just replaced my plugs with e3 diamond fire plugs and i decided to change out my valve cover gaskets becuase they where leaking. Well after all the work has been done my car is still leaking although it dosn't seem to be coming from the covers, now its leaking from my timing cover. Also the oil is in the front part of my cam gear cover. Im not sure where eles its could be coming from also this is a 98 gs300 incase i didn't post that allready. Any help/ advise would be great
My '98 was leaking at the cam seal, crank seal and rear main seal at one point. The timing belt area was full of oil. After changing the crank and cam seals one more time, as well as the cam gear, it finally quit leaking. The technician told me they couldn't actually find anything wrong with the seals, but that this sometimes happens with the 2GS.
Good luck!!
Good luck!!
Well Carbongs Since you are a local expert i think i should recruit LOL. Well so im looking at cam seals i guess anyone know where i could find a write up for this?
saleen90
01-06-14 08:39 AM
