Another NOISE. Please help!
Old May 6, 2008 | 10:07 PM
ISFjimmy's Avatar
ISFjimmy
Unhappy Another NOISE. Please help!
ok i know its been said like 8 million times but i want some fresh answers or suggestions.
my car makes a rattling noise when i hit bumps, even small bumps. sounds to be coming from the rear driver side. i looked in the trunk and took out the carpet to see the top of the strut mount and that was pretty tight, so i know its not that.
the car does not make that noise if it is still and i bounce it up and down, just on bumps.
please help. its really annoying, and worst, embarrassing to have a Lexus that rattles.
thanks guys.
Old May 6, 2008 | 10:17 PM
UncleRay's Avatar
UncleRay
Mine does the same thing EVERYTIME I put my chrome rims on.
Old May 6, 2008 | 10:59 PM
SDDrewGS4's Avatar
SDDrewGS4
check your doorlocks and make sure theres nothing loose on the inside of the door. My passenger side door has something broke inside it that keeps it from locking with the key remote and rattles over bumps. Possibility....
Old May 7, 2008 | 03:58 AM
rl9010's Avatar
rl9010
I have a slight rattle and it comes from my moon roof slider...I hear it coming from the right rear...to cure this i just push it back snug...gl on finding the cause of your rattle.
Old May 7, 2008 | 06:56 AM
GoFaSSter's Avatar
GoFaSSter
Does it rattle on the same bumps if you are pushing lightly on the brake pedal? If applying the brakes makes it go away you will need a fit kit for your brake pads they are moving around. I have this problem right now and it is annoying, but I have not taken the time to fix it.
Old May 7, 2008 | 08:11 AM
rra640's Avatar
rra640
Open the trunk and wiggle everything... brackets, speakers, rear deck, seats, jack, spare tire, lights, etc...
Also... jack up the back end and wiggle everthing that you can see.
Good luck!
Old May 7, 2008 | 12:56 PM
slickgt1's Avatar
slickgt1
check that your swaybar bolts are tight. and your spare is tight.
Old May 8, 2008 | 05:50 PM
praiford's Avatar
praiford
I think slickgt is on the right track. I had a "clunk" sound everytime I went over a speed bump at low speeds. After the dealer changed the struts, it still did it. I took it back, had the tech ride with me and in 5 minutes he said he knew what to do. He torqued everything to spec in the rear and I haven't heard anything since -- that was 3 years and 75K miles ago!
Old May 8, 2008 | 09:18 PM
ISFjimmy's Avatar
ISFjimmy
i highly doubt its anything in my door, u can only hear it when i put down the windows.
Originally Posted by louiegs400
maybe ball joint or some thing not to sure but the last you want is to be sittin on the side of the road
shhhhhhhh... dont say that.
hmmm. gotta try this. where can i find a fit kit at?
Old May 8, 2008 | 10:29 PM
VNN326's Avatar
VNN326
blown shock?
GoFaSSter's Avatar
GoFaSSter
This is when I can hear mine. It annoys me to think that is what others hear when I drive past.
The kit is from Lexus, you should be able to get it from Carson or Sewell or your local dealer. I do not have the part # right now.
Old May 9, 2008 | 06:55 AM
dave11428's Avatar
dave11428
I used to hear something also. I changed the strut and now its fine. My back strut was completely dead and when they are dead they make all kinds of sounds.
Also as one of the other member posted, u need to make sure everything is torqued properly especially the strut nuts in the trunk.
Old May 11, 2008 | 10:37 PM
ISFjimmy's Avatar
ISFjimmy
the rattling noise goes away when i apply the brakes!!!
imma go ahead and look for that fit kit.
thanks guys.
Old May 13, 2008 | 06:27 AM
slickgt1's Avatar
slickgt1
yup, fit kit. Good luck.
Old Jun 8, 2008 | 01:15 AM
ISFjimmy's Avatar
ISFjimmy
UPDATE!
it took my dad a whole minute to install my fit kit. lol.
NO MORE NOISE!!
thanks guys!!!
DMPesso
Feb 15, 2015 12:06 PM
Jimbo2828
Apr 4, 2011 07:46 PM
RONSKI23
Aug 11, 2008 02:09 PM
johnp
RX - 1st Gen (1999-2003)
Sep 3, 2002 08:23 PM
No_bimmer_4_me
IS - 1st Gen (2001-2005)
May 17, 2001 05:59 PM
