Eccentric Bolt
Old Jan 2, 2009 | 01:18 AM
kit cat's Avatar
kit cat
got an exploded diagram and quote for the part.
newgsman>
did soaking the PB Blaster work for the eccentric shaft? Anyone else have any advice?
Old Jan 2, 2009 | 08:36 AM
MJImport's Avatar
MJImport
I had a similar problem with the rear bolts, but I was able to soak the hell out of them and muscle them out. Didn't do me much good though, my car still can't be adjusted better than 9 degrees camber (Lowered with Tein SS)
Old Jan 2, 2009 | 09:17 AM
kit cat's Avatar
kit cat
9??? holy crap!!
Old Jan 2, 2009 | 05:52 PM
newgsman's Avatar
newgsman
newgsman>
I soaked it with Releaze ALL for a couple of days and still no luck. It seems that the shaft of the bolt is apparently seized in the control arm bushing shaft. At least that's what the alignment shop told me. They said if they force the bolt or heat it too much they risk ruining the rubber bushing. So they left it they way it was. My right camber is out -1.30 deg and right toe is out -0.07deg. Left toe is out -0.16deg. Everything else is in spec. I am lowered about 1.5"
I am going to give the PB blaster or release all another shot in the spring when the weather is nice. I'll also be able to see if the 1.3 degrees camber has an effect on my new snow tires. I am trying not to drive the car too much during the winter.
Old Jan 2, 2009 | 09:18 PM
FrankT's Avatar
FrankT
Rust sucks.
wintershot
RX - 1st Gen (1999-2003)
May 17, 2018 11:12 AM
AuntPearl
Dec 14, 2017 07:23 PM
CK6Speed
CL of Hawaii
Feb 12, 2009 10:04 PM
bygtimaish
Dec 22, 2006 06:18 PM
