Help Front Sensor
Old Jan 7, 2008 | 06:52 PM
daintyboy's Avatar
daintyboy
Default Help Front Sensor
Hey guys i need your help. My ball joint broke and i just had it along with the tie rods replaced. However when my ball joint broke apparently one of my front sensors broke too. On my dash are the ABS, VSC and VSC OFF indicators. What is the name of the sensor that i need to replace in order for them to go away along with the price and where can i get it. Thanks
Old Jan 7, 2008 | 07:28 PM
lxgs4's Avatar
lxgs4
Vehicle speed sensor. Call your local lexus dealership to see what the cost is. It shouldn't be hard to replace, should take around 15-20 mins to complete.
Old Jan 7, 2008 | 08:20 PM
daintyboy's Avatar
daintyboy
Thanks. Is it detrimental to get it changed as soon as possible or can i wait to do it.
Old Jan 8, 2008 | 02:26 AM
rgarjr's Avatar
rgarjr
Sounds like your ABS sensor or wire is bad..
Old Jan 8, 2008 | 07:33 PM
daintyboy's Avatar
daintyboy
Yeah it is, can someone please tell me if its something that i need to replace asap or can wait a few weeks and what are the risks of driving without good sensors. Thanks.
Old Jan 8, 2008 | 09:15 PM
Alexus_300's Avatar
Alexus_300
It's fine to drive without it for a few weeks. Are you sure it is your ABS sensor that's broken? What I would do is disconnect your abs sensor from the main line running to your car and take a multimeter and test the resistance on the sensor. Normal operating sensor should register 1.6-1.7 OHMs. Also, take off your ABS sensor and clean it with electrical cleaner.
Old Jan 8, 2008 | 09:41 PM
daintyboy's Avatar
daintyboy
Thanks for the tip. Is it easy to disconnect and reconnect, also what tools do i need get this done. Does the car need to be on a lift or can it be done on the ground? Thanks again.
tanzer
Apr 2, 2014 09:48 AM
david6249
Jan 8, 2014 01:49 PM
steele
Sep 21, 2010 09:35 AM
Rich27
Oct 30, 2009 10:29 AM
drewefx
May 17, 2008 08:13 PM
