View Poll Results: How much ATF does a 2001 gs300 need for drain and refill?
2qt
19
51.35%
4qt
29.73%
other (please let me know how much)
18.92%
Voters: 37. You may not vote on this poll
How much ATF do i need for drain and refill?
Old Nov 14, 2007 | 09:47 PM
swat1727's Avatar
swat1727
Default How much ATF do i need for drain and refill?
just like the title. if i just do a drain and refil, how much ATF do i need? i went the lexus dealer, they told me 4 qts. but from this website
http://bananags.grantham-internation...il/index1.html
he said 2 qts. it's a big difference. so i just want to make sure before i do it. has anyone done it before?
i have a 2001 gs300.
thanx in advance!!
Old Nov 14, 2007 | 09:49 PM
JeffTsai's Avatar
JeffTsai
I think drain and refill pan only is like 2-3quarts. If you do the pump out method(disconnect transmission cooler hose and route it into a bucket while engine is idling) then you can get as much as 5-6 quarts out of the system and then another 1 out of the pan. I've managed to drain 7 quarts at once before.
Old Nov 16, 2007 | 08:51 PM
GSteg's Avatar
GSteg
the manual calls for 2 quarts, but it can also vary depending on how much your driveway angles.
Old Nov 16, 2007 | 10:49 PM
SorrGwa's Avatar
SorrGwa
ok pardon my lack of knowledge. but a quart is roughly a liter right?
i did a drain and fill on my tranny recently. basically didnt know how much so i bought 4 bottles (4L total). what i did was drain it, then emptied it into another container (4L left over empty bottle of washer fluid). filled up roughly 1/2 so about 2Ls. thats how much i put back in. since technically u got probably another 2L in the torque converter, and probably another 2L all throughout the rest of the tranny (i kind of remember someone saying its about 6L total of tranny fluid in the whole system) and its relatively easy if not easier to do than an oil change (oil change u need to take the plastic splash shield a bit so the oil doesnt spew all over the place, might as well change the 2Ls out every other oil change or something.
Old Nov 16, 2007 | 11:03 PM
GSteg's Avatar
GSteg
1 quart is about 0.95L so 2L sounds about right.
Our tranny holds about 12 quarts (11.35L) of fluid.
Old Nov 17, 2007 | 10:51 AM
gs400blue's Avatar
gs400blue
Default ITS 4qt
this i personally did the reseach myself.
this is off a lexus spec....
capacity
1998-2000 transmission cap.
gs300 gs400 is 4 qt
ls400 is also 4 qt
es300 is 8.2 qt.
yes strange isnt it.
Old Nov 17, 2007 | 01:51 PM
pimplux808's Avatar
pimplux808
dang im confused , what is it 4 or 2 ?
many suggestions . . ... .i always go by bananaGs DIY page . . .
Old Nov 17, 2007 | 02:01 PM
chuckb's Avatar
chuckb
2.25 quarts for my 430.
Old Nov 17, 2007 | 03:05 PM
DoWnAqT's Avatar
DoWnAqT
at work they hand out 4qts of the toyota fluid to all the toyota/lexus cars......just call a lexus dealer and ask them.
Old Nov 17, 2007 | 04:15 PM
GSteg's Avatar
GSteg
Toyota/Lexus sells 4L jugs. Convenient if you need a lot of fluid but dont want to pay a lot for individual bottles.
Our manual states that drain/refill takes ~2 quarts.
Old Nov 18, 2007 | 02:03 AM
swat1727's Avatar
swat1727
Thanks a lot guys. i think i will go with 2. btw, if i put a bid less than what i should, would it mess up the tranny? let see, if i just warm up the car and pull shifter from parking to d1? and check the dip stick? cuz i think that's what i am going to do.
Old Nov 18, 2007 | 02:04 AM
swat1727's Avatar
swat1727
no one qt is 4 lt. =)
Old Nov 18, 2007 | 05:03 AM
DASHOCKER's Avatar
DASHOCKER
Drain & fills are a waste of money imo. A great deal of dirty tranny fluid will remain in the tq converter. To extract that fluid, you will need to do a complete transmission fluid exchange via the T-tech machine.
Old Nov 18, 2007 | 05:56 AM
chuckb's Avatar
chuckb
Originally Posted by DASHOCKER
Drain & fills are a waste of money imo. .
not if you do them BEFORE the fluid gets nasty, then it's just regular maintenance and the fluid stays nice and never needs a flush.
wat?
1 US quart = 0.94635295 liters
Old Nov 18, 2007 | 10:05 AM
GSteg's Avatar
GSteg
Make sure to buy more fluid than necessary. I always buy 1-2 quart more than what's required for the job. You never know when you need just a bit more. Plus you wont have to buy as much later on.
If you put just a bit less, you should be okay, but bring it back to the correct level when you can. Our transmission is sensitive to fluid level. If you're below the minimum hot level, your transmission will be slipping.
DO NOT RELY ON THE COLD LEVEL on the dipstick. It is very very inaccurate. You'll find that once you fill the car up to the max hot level, the fluid level will rise over the top when you let the car cool down.
Turn on your engine and shift from gear to gear with 5 seconds in between. Ideally, the car should be driven for about 10-15 minutes. Thats when the fluid should be in normal operating temperature. Park your car and then check your dipstick. Fill it up to max hot.
