quick question..........
Old Nov 6, 2007 | 09:15 PM
LexXxuS101's Avatar
LexXxuS101
Question quick question..........
Hi, I have question guys, did any of you have this problem. When I make turns and at same time apply the brake I hear strange noises coming from front wheels, I was thinking maybe ball joints? But its only happen when I apply the brake, when I make turns and not touching brake I don’t hear anything. Maybe I need new rotors?......weird
Old Nov 6, 2007 | 09:25 PM
GSteg's Avatar
GSteg
What kind of noise is it? Grinding? Popping? Clicking?
Old Nov 6, 2007 | 09:40 PM
LexXxuS101's Avatar
LexXxuS101
hey GSteg. its like clicking, popping somethin like that
Old Nov 6, 2007 | 10:01 PM
GSteg's Avatar
GSteg
Its probably the balljoints. When you apply brakes, the weight of the car will push down on the balljoint. I had the same problem where the balljoints made a popping/clicking noise when applying the brakes while making a turn.
Get both sides replaced immediately. $120 for a pair of balljoints is cheaper than $1000 for new fender, balljoints, etc.
Old Nov 6, 2007 | 10:40 PM
LexXxuS101's Avatar
LexXxuS101
Tanks GSteg. il definitely going to change ball joints during this week. is it serious work should I let local auto shop do the work? How much would be labor? Going to stop by dealer tomorrow ask them about ball joints if they have in stock.
Old Nov 6, 2007 | 10:44 PM
kit cat's Avatar
kit cat
it's not too bad but you'll need to get alignment. do a search and there are plenty of informative threads.
Old Nov 6, 2007 | 11:06 PM
GSteg's Avatar
GSteg
You should get the shop to check out the tie rod while you're at it.
The balljoint replacement shouldn't take more than 1.5 hours total for both sides. I replaced by balljoints without doing an alignment. Most people get an alignment after the balljoint change because they change their tie-rods at the same time
20012003rx
RX - 1st Gen (1999-2003)
Jan 30, 2015 06:36 PM
Baptizer
Sep 3, 2014 12:21 PM
mikemareen
Oct 19, 2009 11:37 AM
krappy
Suspension and Brakes
Feb 17, 2009 03:19 PM
azari
Aug 1, 2004 01:13 PM
