The air conditioning on My 2001 GS430 is blowing hot air when turned above 65 degrees. The setting is on auto, but once I move the temp. up the vents start blowing warm air and the auto light turns off. At 65 degrees degrees the air works and is very cold. Has this happened to any one else at all? What can I do for this? Thank you for your help
I have the same problem with my LS400 after having something installed.
The A/C only blows freezing cold and anything abover "Max Cold" causes it to blow hot??
