19's vs. 20's
Old Sep 10, 2007 | 08:40 PM
edouble's Avatar
edouble
Default 19's vs. 20's
I love the horsepower that my GS400 puts out. I have been looking at wheels for it but as much as I want the car to look great, I don't want to take away from the performance. I currently have 16's on it. Does anyone know if there is a certain size I should go with if performance is my main objective? If so could you send me a link?
Thanks
Old Sep 10, 2007 | 09:11 PM
DarKnight's Avatar
DarKnight
Maybe some 18" racing wheels.
Old Sep 10, 2007 | 10:53 PM
bighitbike's Avatar
bighitbike
If you're stuck on 19's or 20's then i'd go with 19 for sure. If not get some 18" BBS'...Yummm
Old Sep 11, 2007 | 06:08 AM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
If you really like the look of 20's then go find some really light alloy 20's ... and remove the spare tire to compensate for the added weight ...
Old Sep 11, 2007 | 07:32 AM
gsproject's Avatar
gsproject
Also keep in mind the cost difference between the 2 different tire sizes. 20's generally are cheaper than 19's and more common.
You are more likely to find better quality 20 inch tires on sale or specials than 19 inch tires.
Old Sep 11, 2007 | 07:51 AM
LEXUS_KID's Avatar
LEXUS_KID
Old Sep 11, 2007 | 09:06 AM
FlavesLex's Avatar
FlavesLex
Performance= 18"
Looks= 20"
Looks w/ a lil performance sacrafice= 19"
Old Sep 11, 2007 | 09:26 AM
bighitbike's Avatar
bighitbike
I think looks are very subjective. I personally would rather have 19's because for me, 20's put the car too high off the ground.
Old Sep 11, 2007 | 09:28 AM
golfkid777's Avatar
golfkid777
Elliot... Thats what a proper suspension is for mang. Sure you might have to tub out some fender, but with a little ingenuity you could make 21's sit like 19's.
Old Sep 11, 2007 | 10:27 AM
PushinLEX's Avatar
PushinLEX
I took out my spare tire and jack assembly when I put on my 19's to help with a bit of weight reduction. The problem is, the spare tire is used to hold cargo weight and stabalizes the truck bed. W/out the spare in, if you put any cargo in that weighs more than 20 lbs, you can see the depression it creates because of the lack of support that the spare used to provide. Has anyone addressed this problem?
Old Sep 11, 2007 | 10:47 AM
4ntvings's Avatar
4ntvings
19's.
the gs400 has reported 300hp (not at the wheels of course), but still. v8 is v8 = decent size cajones...know what i mean. do what you like.
Old Sep 11, 2007 | 10:52 AM
onedropz's Avatar
onedropz
weight reduction on a 4,600 lb car made for luxury?
anyways... if you take 1lb off the wheel it will effect your performance more than if you take 1lb off the chassis.
Old Sep 11, 2007 | 11:29 AM
benzo555's Avatar
benzo555
Well I have a supra TT spare then I cut a custom wood crossbar and solved the problem. The supra TT spare weighs at least half of the full size just in case for those long trips.
Old Sep 11, 2007 | 11:37 AM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
#1 The GS does not weigh 4,600 lbs. it weighs more around 3,700 - 3,800 lbs.
#2 The GS is classified as a luxury-sport sedan ...
#3 True taking weight off wheels is more effective than taking weight off the chassis, but reduced weight is reduced weight, and it helps either way ...
Old Sep 13, 2007 | 11:30 AM
onedropz's Avatar
onedropz
oooh, glanced at the door sill while back, must of seen a different number.
