Headlight CLEANER KIT
Old Aug 29, 2007 | 08:01 PM
CohGS300's Avatar
CohGS300
Default Headlight CLEANER KIT
Hi, I am new to CL and I saw this thread about headlight restoration kit cleaner and that person has the same problems as I do. My 2001 Gs headlight is dirty and foggy, so I want to know where can I buy the cleaner kit and what is the brand.
Thank You
Old Aug 29, 2007 | 10:08 PM
Downfall75's Avatar
Downfall75
I use Meguiars Plastx. It works nicely for me, personally. You can get it at any auto shop.
Old Aug 29, 2007 | 11:42 PM
chrispy's Avatar
chrispy
Use it with a rotary buffer for best results. I've always thought Plastix didn't work as well as people would tell me until I used a buffer.
Old Aug 30, 2007 | 03:28 AM
GS300Rich's Avatar
GS300Rich
I would definately try the plastx, works very well
Old Aug 30, 2007 | 05:34 AM
Rock-a-Lex's Avatar
Rock-a-Lex
One thing that I have personally noticed in the past buffing old headlights...they come out clear and smooth but at night with the headlights on you see a slight haze. I don't believe that you can achieve the crystal clear look again like brand new headlights provide but it's better than having pitted ones that's for sure. Anyone else know what I'm talking about???
Old Aug 30, 2007 | 06:26 AM
LEXUS_KID's Avatar
LEXUS_KID
I think someone on here wet sanded and buffed them
Old Aug 30, 2007 | 08:16 AM
Saiji's Avatar
Saiji
I know exactly what you're talking about. I buff them, wax them, plastix, everything, it gets clearer, but when i turn on the lights at night time....it's still hazy...could it be the inside? or is it still the outside?
Old Aug 30, 2007 | 08:42 AM
Rock-a-Lex's Avatar
Rock-a-Lex
It is still the outside, for some reason once the top layer of plastic is milled and buffed it will never be the same. So if you have rather new headlights but with a couple of minor specs it might be best to just leave it alone. If the headlights are riddled with chips and marks then of course buff away; it can't get any worse then.
Oh, BTW I have wetsanded headlights before and it comes great but you still have this haze of which we speak of. I just wound up buying new ones in the end.
Old Aug 30, 2007 | 09:15 AM
Saiji's Avatar
Saiji
darn, thats the last thing I wanted to do...anyone have any suggestions? I tried almost everything out there. Even that head light restore kit from ebay. Nothing seems to work.
Old Aug 30, 2007 | 09:23 AM
JLAM's Avatar
JLAM
I also used the meguiars plastx on my cars with good results. I didn't get any hazing. The hazing may be caused by residue or build-up left from cleaner. When you apply the cleaner...make sure the surface is clean & cool and not in direct sunlight.
Old Aug 30, 2007 | 09:26 AM
Saiji's Avatar
Saiji
ok. Ill give it try....crossing my fingers
Old Aug 30, 2007 | 09:57 AM
PushinLEX's Avatar
PushinLEX
The re-hazing is due to the fact that once you've wetsanded and buffed your headlights, you essentially removed the stock clear-coat and UV protective layer. Since you've removed the protectants on your plastic headlights, your headlights are now more proned to oxidation and faster re-hazing.
Look here:
https://www.clublexus.com/forums/sho...d.php?t=298004
Old Aug 30, 2007 | 10:24 AM
Saiji's Avatar
Saiji
Thanks for the link pushinlex. That's a lot of work just for head lights..damn.
Old Aug 30, 2007 | 11:36 AM
PushinLEX's Avatar
PushinLEX
NP.....
BossGS4's Avatar
BossGS4
Look here:
Since this is the case would using headlight film essentially seal eveything again after you do your buff/polish job on the lenses ?
