Lost power to 12v Lighter Socket
Old Aug 12, 2007 | 09:46 AM
TomLee's Avatar
TomLee
Default Lost power to 12v Lighter Socket
I spliced my signal wire into the 12v lighter socket wire, and it worked great for a couple days and now it just suddenly lost all power! Whats up with that? If i blew a fuse doesnt that mean all the things on that harness would have lost power? The green leds for the 12v socket and the ashtray still come on!
Ahhh this keep hapenning to me What am i doing wrong?
Old Aug 12, 2007 | 10:37 AM
TomLee's Avatar
TomLee
Ok i replaced the fuse but it just burns up everytime....should i reconnect the signal wire to a differnt power source?
Old Aug 12, 2007 | 10:40 AM
sbgs400's Avatar
sbgs400
you probably have too much draw on the one circuit now. if you're sure everything is wired correctly then you can bump the fuse up to a higher rating.
Old Aug 12, 2007 | 10:47 AM
TomLee's Avatar
TomLee
what would you reccomend?
the stock fuse is 15amps, i attached a signal wire that goes to a kenwood 6202 (dunno if any of this info helps).
Old Aug 12, 2007 | 11:00 AM
TomLee's Avatar
TomLee
Nevermind, it will poabbly void any warrenty i have and i dont want to over heat the wires and cause a fire or something. I dont know what to wire it to though =(
Old Aug 12, 2007 | 11:10 AM
GSoup's Avatar
GSoup
CL Folding 10,000
You shouldn't be powering an amp via the cigarette lighter. What you should do is wire it directly to the battery with the proper wiring and fuses. not sure exactly how you wired it up but you should read up on how to do it from here. Hope this helps.
http://www.caraudiohelp.com/how_to_i..._a_car_amp.htm
Old Aug 12, 2007 | 11:57 PM
TomLee's Avatar
TomLee
the amp is wired directly to the battery, its the signal cable that was wired to the 12v cig lighter.
Old Aug 13, 2007 | 09:01 AM
sbgs400's Avatar
sbgs400
if you're talking about the remote turn just use the same one the radio uses.
Old Aug 13, 2007 | 09:08 AM
GSoup's Avatar
GSoup
CL Folding 10,000
Yup. The remote should be wired to the radio harness not the lighter.
D3V3LOP3R
Feb 4, 2015 09:45 PM
IneednSC
Feb 19, 2014 02:01 PM
Tact
16
Jan 12, 2013 12:56 PM
blknfury
Nov 29, 2007 11:00 AM
JWS3
GX - 1st Gen (2003-2009)
24
May 18, 2006 03:20 PM
