SQUEAK driving me NUTS!
Old Dec 28, 2001 | 04:26 AM
mdgold's Avatar
mdgold
Default SQUEAK driving me NUTS!
My '02 GS430 is outstanding exc for a "squeak" coming from trunk/rear deck with turns, bumps etc. Cant reproduce it with the car stationary and rocking the deck lid.
Any thoughts before going to service?
Thanx
Old Dec 28, 2001 | 05:31 AM
///MDex's Avatar
///MDex
Try putting some WD40 on whatever joints, or contacts points between the trunk lid and body you can access where the sounds seems to originate from.
Only thing I can think of. May be just a squeaky suspension component that the dealers needs to regrease for you.
Let us know what transpires.
Old Dec 28, 2001 | 11:39 AM
Erfan's Avatar
Erfan
bushings
Old Jan 4, 2002 | 09:13 PM
Erfan's Avatar
Erfan
Did you ever find out where the squeaks where coming from , I bet they were the bushings
Old Jan 4, 2002 | 10:53 PM
DevilDog's Avatar
DevilDog
Your problem is the rear strut springs. They creak and make noise when compressed against the strut spring holder. Try spraying some wd40 on the bottom of rear springs where they meet the strut. If it goes away for a while then returns. The springs have to have some insulation on them. This is quickly becoming an issue and lexus is looking into it. Seen it many times already. Let us know what happened!
Old Jan 5, 2002 | 06:17 AM
Erfan's Avatar
Erfan
Can we use break free CLP? I think that would work better than the WD-40 which gums up mechanisms over time. DevilDog you should be familiar with break free, you used it to clean your
M16-A4 with aperture sights and 1 in 9 inch twist rate
Old Jan 5, 2002 | 06:25 AM
DevilDog's Avatar
DevilDog
Exactly! lol
Yes you can, but adding the lubricant is only to see if the springs are the problem. Eventually the creak will return. Currently as a long term fix, we remove the spring and slide a 12" piece of clear tubing over the lower end of the spring to insulate it against the strut plate.
Old Jan 5, 2002 | 06:58 AM
Erfan's Avatar
Erfan
Devildog,
I did not know that you were a Master Lexus tech. That is awesome
Old Jan 7, 2002 | 04:15 AM
mdgold's Avatar
mdgold
Thumbs up SQUEAK Follow/Up
I'm due in to Lexus service this week and will tell you what the result is-thanx for all your advice-I'm going to take all replies from CLUBLEXUS to Lexus scv manager and see what they think
Will keep you posted
Old Jan 7, 2002 | 05:41 AM
DevilDog's Avatar
DevilDog
The best thing to do is to demonstrate the noise to them. Ask to test drive with the service writer or technician. This way there is NO dought what noise your concerned about. Also the dealership can not say they never heard anything wrong, because you just showed them the noise. And they heard it.
Good Luck!
Old Jan 7, 2002 | 05:49 AM
mdgold's Avatar
mdgold
Thanx-Willdo! (its so obvious we should have no trouble demonstrating it)
Old Jan 7, 2002 | 06:39 AM
Erfan's Avatar
Erfan
Good luck and keep us all posted of your status
Bix49
Mar 3, 2015 09:11 AM
lexluva
Sep 6, 2010 07:56 PM
2UX31 YM
Mar 28, 2008 11:37 AM
jtsai
Dec 14, 2006 12:38 PM
Bercasio
May 5, 2006 03:08 PM
