is there a part missing?
Old Jun 15, 2007 | 08:10 AM
Vitaliy23's Avatar
Vitaliy23
Default is there a part missing?
i just noticed this today , it looks like there were 2 bolts missing or something does anyone know whats supposed to be there ? left side of the engine
[IMG][/IMG]
also has anyone here had their engine cleaned professionaly and did it cause any problems?
Old Jun 15, 2007 | 10:57 PM
Vitaliy23's Avatar
Vitaliy23
thanx guys for all the response
Old Jun 16, 2007 | 10:17 AM
Ay-nako's Avatar
Ay-nako
Stop the Copy!
nah nothing is missing.. ive got em tii and no it wont cause any problems..
Old Jun 19, 2007 | 11:01 AM
lx4life's Avatar
lx4life
Well on the car I am looking at now has a 1/2" flat looking wire coming from there under the air filter tube to one of the top nuts holding the strut, he says it is a grounding wire. Could that be true and why?
Old Jun 19, 2007 | 06:26 PM
Chenzo26's Avatar
Chenzo26
Have someone take a pic of their GS3 and compare. It should be too hard.
Old Jun 19, 2007 | 06:27 PM
whazzzzuup's Avatar
whazzzzuup
Are you missing the exhaust manifold cover?
Old Jun 19, 2007 | 07:06 PM
BurgandyGS's Avatar
BurgandyGS
They are there to attach hooks to for ease of pulling the engine out. At least thats what I used them for. There's no real other purpose that I can think of.
Here's a pic of mine on the intake side.Your safe, not missing anything.
Old Jun 20, 2007 | 11:41 AM
lx4life's Avatar
lx4life
Look at the pic I have attached. i circled it red.
Old Jun 20, 2007 | 09:48 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
^^ that doesnt look original looks like somebody rigged a ground wire to the block.
Old Jun 21, 2007 | 12:52 AM
mikal's Avatar
mikal
it's there so you can hook it up to an engine hoist/cherry picker
Old Jun 21, 2007 | 06:53 AM
lx4life's Avatar
lx4life
so where is the orignal ground wire located at
Old Jun 21, 2007 | 07:01 AM
DASHOCKER's Avatar
DASHOCKER
Looks normal to me, and no different than any other engine block including the 1uzfe block. Just remember that engine blocks are milled and honed. The portion circled was obviously milled and honed.
Old Jun 21, 2007 | 08:11 AM
BccGS300's Avatar
BccGS300
When an engine is manufactured, it is designed to fit into many different cars. Now toyota hasn't used the 3.0 I6 in many cars in the past few years but the design has been around for along time. The holes that are drilled into your cylinder head have probably been a part of the design plan since the engine was originally put into use. It doesn't pay to redesign it for every single application. Those holes were never used in the gs. It can be used to place a hook in so you can lift the motor out. The pic of the gs with a ground wire attached to it is definetly not original. Somebody Somewhere put that in for a reason that I can't figure out. In short, nothing to worry about, my gs and everybody else's has the same holes.
Old Jun 21, 2007 | 08:19 AM
Euphoric's Avatar
Euphoric
Yeah, the GTE comes with the hooks already there. For some reason though those hooks are NOT a replacement part as I lost the front one and called Toyota about it, no dice
Old Jun 21, 2007 | 08:28 AM
boosted-gs's Avatar
boosted-gs
those are where you connect your lift lugs when removing the engine. someone please correct me if i'm wrong.
