How do we clean the MAS
Old Jun 4, 2007 | 09:37 AM
go4dabukz's Avatar
go4dabukz
Default How do we clean the MAS
I've read a lot of threads regarding sluggish throttle response off the line.
I'm going to be cleaning my throttle body ASAP.
Some have replaced their MAS with great success. Can I just clean it instead of replacing it?
How do I go about cleaning it?
Thanks guys. CL is the best source for help!
Old Jun 4, 2007 | 09:49 AM
KRGS4's Avatar
KRGS4
Don't clean your MAS...the mass air flow sensor is very sensative.
if damaged it will cost approx $550 (junkyard) or $1125 (dealer) to replace.
Just Do
1. Throttle plate/body cleaning
2. Seafoam Treatment (do a search)
3. BG44K if you can get some
4. Full Tranny Flush with Toyota Type IV fluid
5. Rear Diff fluid change
6. Fresh set of Plugs (NGKs)
7. Then reset your ECU
You should get some throttle response... ie "snap" back...right off the line.
Old Jun 4, 2007 | 10:41 AM
go4dabukz's Avatar
go4dabukz
Just Do
I hear this isn't good for high mileage cars. I have approx. 150,000 miles. Good or bad idea? Is this the same as a trans. fluid change?
Old Jun 4, 2007 | 10:42 AM
GSteg's Avatar
GSteg
As long as you spray the cleaner into the MAF gently, you wont ruin it. Many people have done this with success. I've probably cleaned mine over 5 times already with no issues.
A new MAF cost $200 from the dealer and it takes 5 minutes to replace.
Old Jun 4, 2007 | 10:43 AM
gobears's Avatar
gobears
Just Do
I thought most people here use TM spark or Denso Irridium?? NO?
Old Jun 4, 2007 | 11:41 AM
GSteg's Avatar
GSteg
you can use NGK. Nothing wrong with that. In fact, search around and many people are getting longer life out of their NGKs than Denso. Its not as aparant in the GS forum because everyone likes to stick to Denso. I went from TM to denso and my car was slower. It's noticeable too
My next plugs if I dont go with TM will be NGK.
Old Jun 4, 2007 | 11:52 AM
go4dabukz's Avatar
go4dabukz
One member suggested using a q-tip to clean the wires! I've been searching the net and many other forums suggest not to touch the wires with anything.
So soaking them at low pressure and using a blowdrier to dry them, is a good way to go?
Old Jun 4, 2007 | 11:58 AM
GSteg's Avatar
GSteg
No. Buy yourself a can of CRC Mass Air Sensor cleaner (~$4). Spray it into the MAF lightly. Spray it somewhere else to get a feel of the pressure, before you go shooting it into the MAF.
The CRC evaporates quickly so there is no need to blowdry. In fact, do not try to blowdry anything
Old Jun 4, 2007 | 12:00 PM
go4dabukz's Avatar
go4dabukz
perfect! Thank you!
Tjfaz
Mar 18, 2013 04:09 PM
MPLexus301
Apr 1, 2009 12:45 PM
matrixgts
Nov 9, 2008 05:20 AM
4urxtc
Jan 25, 2006 01:58 PM
Taka
May 14, 2002 12:58 PM
