How do I replace a tail light bulb?
Old Feb 12, 2007 | 01:10 PM
ohmike's Avatar
ohmike
Default How do I replace a tail light bulb?
It appears as though I need to remove the entire tail light? I'm used to being able to just twist the bulb out of the enclosure, but this one seems to be sealed.
Old Feb 12, 2007 | 02:17 PM
sleeper408's Avatar
sleeper408
Yes. You have to pull out the entire tailight to change the bulb.
http://lexusmodz.netfirms.com/
Old Feb 12, 2007 | 04:34 PM
Bigbea's Avatar
Bigbea
It's really easy. There are two screws on the outside by the trunk lid and two on the inside of the trunk. Then it slips right out. Takes 5 minutes
Old Feb 12, 2007 | 06:15 PM
pardesi's Avatar
pardesi
Jut did mine half hour ago. The bolts mentioned are hidden under the caps. Remove the inside and outside caps and you should be able to see the bolts.
Old Feb 12, 2007 | 09:32 PM
ohmike's Avatar
ohmike
Thanks, that was easier than expected. The link with pictures was especially helpful.
jcallows
Jan 24, 2013 01:28 PM
xsaint53
Aug 22, 2008 02:42 AM
infa_red
Jan 11, 2008 04:26 PM
inkblot
IS - 1st Gen (2001-2005)
Oct 3, 2005 04:47 PM
twenty1
Lighting
Jun 10, 2004 09:34 PM
