Quick Lexus Manual Question
There are 2 volumes and 1 electrical. So technically there are 3. One of the volumes focuses on diagnostics for the most part, while the other one has write-ups. You NEED both.
Jonny
Jonny
I have Vol.2 and the Electrical Wiring Diagram. I have not seen the Vol 1. but the index in Vol.2 shows that Vol 1. has " Introduction, Maintenance, Preparation, Service specifications and Diagnostics"
If I were to get one for starters I would get Vol 2. first. It seems to have the main systems w/ diagrams and specs.-Body engine Interior,exhaust,cooling,suspension.
Volume 2 covers most of the engine/transmission/cooling/brakes/suspension and body. If you plan to DIY or need a detailed reference buy the volume2.
Volume 1 covers the diagnostic part and needs to read codes and diagnose the problem. Special equipment is needed.
It is good to have them both, but if you can only purchase one then get the volume2.
As pointed out there is a seperate book (suppliment?) that covers the electrical.
Good Luck
note: The above is true for 98 service manuals. The others should be the same.
Salim
Good Luck
Salim
Arcturus
Dec 5, 2013 06:12 PM
Kyle4207
IS F (2008-2014)
Feb 15, 2012 08:26 AM
