Look at what i made today
holy cow that looks cool!!
can you do a write up on how you did it? materials used, methods of measurement, etc...
how do you remove it to clean/swap the filter?
how are you piping cooler air into that area?
have you noticed less heat soak?
is there a lining on the interior to further insulate the heat?
sorry for so many questions but c'mon- you knew they were coming.
actually, it's made out of a dense foam material, i forgot the name of it but it feels like plastic. i was going to use abs plastic but it cost more and i figure it might be harder to form and mold it.
sorry for so many questions but c'mon- you knew they were coming.It's not quite complete the way i wanted it to be. there's a slight gap at the very bottom that i need to find a way to seal up.
This is basically more of cover (for now) than a box. i Guesstimate the top dimension and the depth and cut out a oval 3.75" x 4" hole to fit the piping.
Test fitted the cover and sand down what i need to make a better fit.
the hardest part of the installation was putting the intake filter on. it's kinda tricky but i had to force one of my hands inside while i got a long screwdrive to tighten it up.
i don't have the technical spec on performance side of it as i just wanted to block the hot air coming in from the fan belt etc,etc.
. Nice work bro
