Looking for door actuator
Old Aug 14, 2006 | 09:55 AM
STONER's Avatar
STONER
I need passenger rear.
Old Aug 14, 2006 | 12:26 PM
Dx3's Avatar
Dx3
I need passenger front
Jonny
Old Aug 14, 2006 | 01:14 PM
rra640's Avatar
rra640
I need passenger front and rear!
Old Aug 14, 2006 | 02:37 PM
rra640's Avatar
rra640
I called my local dealer and asked them for a price on the front and rear passenger door lock actuators.
They quoted me:
$296.55 for the front (said it only came with the actuator and lock assembly?)
$128.29 for the rear (actuator only)
Does this sound right?
Old Aug 14, 2006 | 07:23 PM
treimche's Avatar
treimche
I would be in for a front passenger actuator as well (if the price is good). Sounds like it's a VERY common problem and it's too bad Lexus doesn't recall this!
Old Aug 14, 2006 | 08:34 PM
3dog's Avatar
3dog
Default Door Actuators
So how does one know if he needs front or rear or drivers or passenger side?
Mine works part of the time and I only use the drivers door so what should I do to figure out what I need?
I was sure hoping there was only one
Ivan
3dog
Old Aug 14, 2006 | 08:36 PM
Dx3's Avatar
Dx3
Ivan
3dog
Ivan,
Each door his its own actuator that controls the electronic locking/unlocking of the door. If your other doors are locking/unlocking when you use the drivers lock/keyfob then you will probably only need to replace your drivers one.
Hope this helps,
Jonny
Old Aug 14, 2006 | 08:53 PM
3dog's Avatar
3dog
Originally Posted by Dx3
Ivan,
Hope this helps,
Jonny
Hey thanks, yes they do work but like I said it has become sporadic.
Ivan
3dog
Old Aug 15, 2006 | 04:53 AM
adale's Avatar
adale
Default actuator
My drivers door had the failure yesterday. Took apart the door to see if could fix it. Yes a DIY'er can disassemble and reassemble to door, but OMG it is not easy. If you are a casual DIY'r you might thing twice about this. As for the price of the part, I will call Lexus today for that. I checked out the acutator and the coil is open on mine so it can't be repaired. I will post a detailed description of the door disassemble if any body wants. No pictures........no camera!
Old Aug 15, 2006 | 06:53 AM
corkycal's Avatar
corkycal
i think you need a special star looking socket (torx?) to take this unit off the door.
someone needs to do a write up on this. it may be a different procedure for the front and rear doors.
Old Aug 15, 2006 | 11:26 AM
adale's Avatar
adale
The special socket is a torx. I don't remember the number.
Old Aug 15, 2006 | 01:29 PM
RacingLuxury's Avatar
RacingLuxury
Default Look here!!!!!
I've had this problem on both of the passenger front and rear doors. I can get these parts as follow:
Front: $230+shipping
Rear: $240+shipping
No shipping charges in Houston if you pick it up locally.
The rear ones costs more for some particular reason. You can ask the details with the dealer on that. I can also install these for you for $50/door if you're willing to come to Houston. Just PM me. Thanks.
JL
Old Aug 15, 2006 | 03:04 PM
bmgs400's Avatar
bmgs400
Yeah...mine are acting up as well..have been for a couple years now. Get's worse when it's very hot. Funny thing is sometimes they work and sometimes they don't...operation latency and temperature all seem to factor in the malfunctioning equation. So I'm using the Mexican (Manuel) manual door locks. $240 a pop is waaaayyy too much for a lock. This should be covered (recall) by Toyota...IMHO.
Old Aug 15, 2006 | 04:05 PM
3dog's Avatar
3dog
Rear: $240+shipping
JL
Hey do you know how much the one for the
Drivers side Front door would be?
Thanks
Ivan
3dog
Old Aug 16, 2006 | 06:58 AM
RacingLuxury
Default It's worth it.
I agree with you, but call around and you'll probably only get higher quotes. I just called Lexus in Houston and got quoted fronts: $291.01 and rears: $289.25. The most frustrating thing is that if you don't change it, eventually it will go out completely and you won't be able to lock your car remotely. You'll have to walk all around to the passenger rear side to just lock your car. I've been there and it sucks! Especially during the rain. Like someone said in this post that it's a wear and tear part. It's prone to go out but unlucky for me mine's went out one week after another. It's worth that much. We pay for what we drive.
